Banshee Gearing
ok I need new gearing both my front and rear Sprockets are shot. I was running 15/41. I drag race a Tail Ride what would be the best gearing to go with? I was thinking about trying 14/40
390873[/snapback]
I ride at GlamASS and runa 13/42 with stroker mods :cheers:
i played with gearing alot..what type of riding do u do? i use a 13/43 in the sand im not as fast on the top end but i gain a bit of low end..in the hard pack i run a 15/39 and it flys on the top scary fast..but low end sucks.
It's sometimes tough to find a medium that works for both trail riding a well as draggin.I'd start with finding your best ratio for trail riding and then try out a few drags to see how you make out.The sprockets you chose for trail riding may work out in drag racing because you can start out in a taller gear.Your opposition may get ya in a 500ft rip but you may smoke him in 300ft. It depends and what you're up against.
There's a sprocket ratio chart tumbling around the HQ that may help you.If i find it I'll post it.
