Brocster350 Posted July 9, 2005 Report Share Posted July 9, 2005 I have toomey springs which are fairly old and when my bansh is warmed up good I keep losing clutch pull at the lever and I have to adjust on teh bars constantly. I'm running bel-ray Gear Saver 80W. Could my springs be too worn. Quote Link to comment Share on other sites More sharing options...
fixitrod Posted July 14, 2005 Report Share Posted July 14, 2005 Sounds like you need to make sure your clutch is properly adjusted or the adjuster on the pressure plate hasn't come loose. Quote Link to comment Share on other sites More sharing options...
Brocster350 Posted July 15, 2005 Author Report Share Posted July 15, 2005 I thought the same thing but once teh engine cools there is no slack in the cable again I have about 4 friends with banshee and toomey springs and no one has this problem. Quote Link to comment Share on other sites More sharing options...
Meat Posted July 16, 2005 Report Share Posted July 16, 2005 Do you know about the little clutch alignment arrow embossed on the engine case ? Quote Link to comment Share on other sites More sharing options...
fastbanshee4u Posted July 17, 2005 Report Share Posted July 17, 2005 Sounds to me like the steel plates are getting hot and warping,therefore taking up all the clutch freeplay.I think its time for a new clutch kit. Quote Link to comment Share on other sites More sharing options...
