glamisrat Posted July 5, 2005 Report Share Posted July 5, 2005 My banshee has a stage 4 porting,by a local shop (very large ports!). I was thinking of a 4mm stroker, but dont know if my portig would be compatible.I do not know the location of the ports,but have the capability of measuring them.I was wondering if by putting a spacer plate on the bottom of the cylinders I could correct the porting for the stroker? Quote Link to comment Share on other sites More sharing options...
rocketboy Posted July 5, 2005 Report Share Posted July 5, 2005 (edited) your really gonna need to talk to a good porter who can actually index your jugs,measure and see what they can do for you ,stroker porting is more complicated than standard stock crank and rod length porting ,i doubt your gonna be able to use a spacer plate and youll need custom cut domes and ports will most likely need dropped alot to work Edited July 5, 2005 by rocketboy Quote Link to comment Share on other sites More sharing options...
wayfst Posted July 5, 2005 Report Share Posted July 5, 2005 yeah, stroker porting drops the port to match the top of the piston. most porting for stock bikes raise the ports. on my 7mm stroker i don't even run a base gasket, the cylinders are glued right to the cases to get the ports as low as possible. Quote Link to comment Share on other sites More sharing options...
glamisrat Posted July 6, 2005 Author Report Share Posted July 6, 2005 Thank's for the info Quote Link to comment Share on other sites More sharing options...
