1badshee350racer Posted July 1, 2005 Report Share Posted July 1, 2005 i have the 28 PWK's and i want to get rid of the TORS where is the box to unplug it and is that all i have to do ???? Quote Link to comment Share on other sites More sharing options...
spurdy Posted July 1, 2005 Report Share Posted July 1, 2005 I don't think I have ever seen PWK's intergrated with TORS. Are you sure??? Quote Link to comment Share on other sites More sharing options...
thegroup Posted July 1, 2005 Report Share Posted July 1, 2005 see those 2 boxes just above the carbs, just un-plug them Quote Link to comment Share on other sites More sharing options...
1badshee350racer Posted July 5, 2005 Author Report Share Posted July 5, 2005 I unpluged the TORS from the stock carbs and installed the new carbs and left the plugs hanging. but the switch from the TORS is still in the throttle and it wont start unless the throttle is engaged enough where it is not making contact with the switch. once i get it running and then i let the throttle go it will kill. So what do i do now???? am i missing somthing ? Also the 28 PWK's DO NOT HAVE TORS instaled on them Quote Link to comment Share on other sites More sharing options...
Handyman Posted July 5, 2005 Report Share Posted July 5, 2005 I unpluged the TORS from the stock carbs and installed the new carbs and left the plugs hanging. but the switch from the TORS is still in the throttle and it wont start unless the throttle is engaged enough where it is not making contact with the switch. once i get it running and then i let the throttle go it will kill. So what do i do now???? am i missing somthing ? Also the 28 PWK's DO NOT HAVE TORS instaled on them 388758[/snapback] Cut the wires at the throttle that go to the TORS system. Once the wires are cut make sure the electrical connectors are all disconnected from the box. Once that's done the thing should run. The box is on the left side of the frame under the gas tank. Quote Link to comment Share on other sites More sharing options...
1badshee350racer Posted July 5, 2005 Author Report Share Posted July 5, 2005 GOT IT FINALLY THANKS Quote Link to comment Share on other sites More sharing options...
