Low Compression
To test compression the engine should be cold, engine off, throttle open and kick until the gauge doesn't increase any more.
387258[/snapback]
Why WOT???? Compression is the same with or without fuel isn't it? Well.. maybe not....Is this the reason?
  • 2 weeks later...
387457[/snapback]
WOT is so you get all the air you can and not the fuel oil mixture. If you get the oil in there it can seal the rings and give you a good reading even though your rings could be leaking. And if you have to much liquid in there the reading could be higher than it should be.
Keeping it WOT while kicking gives a more accurate reading for more than one reason.
