badlarry Posted June 12, 2005 Report Share Posted June 12, 2005 Hi, I just filled my crankcase and it is pissing oil out the breather line. I think I filled it o.k. and the head gasket is o.k. maybe I'll just get new o-rings and change them to be sure. What does everyon think will cause this?? My coolant is also a little low at times but I never see it going out the overflow tube.?? Help!! Quote Link to comment Share on other sites More sharing options...
spurdy Posted June 13, 2005 Report Share Posted June 13, 2005 What o-rings are you going to replace if you have a head gasket? I would say, based on the limited info given that you overfilled the tranny. Are you sure it is the tranny tube pissing? Quote Link to comment Share on other sites More sharing options...
jmoore Posted June 13, 2005 Report Share Posted June 13, 2005 Make sure both vent tubes are not clogged. I recently had this problem but my dumb ass wrapped the rear vent hose around my boot clamp while putting the carbs back on after jetting. just a thought Quote Link to comment Share on other sites More sharing options...
mybadbanshee Posted June 13, 2005 Report Share Posted June 13, 2005 give a little more info but it definatly sounds like you over filled it. Quote Link to comment Share on other sites More sharing options...
sheefreak Posted June 16, 2005 Report Share Posted June 16, 2005 How much did you put in? Quote Link to comment Share on other sites More sharing options...
05bansh Posted June 16, 2005 Report Share Posted June 16, 2005 Hi, I just filled my crankcase and it is pissing oil out the breather line. I think I filled it o.k. 380773[/snapback] That right there doesnt sound good! You think you filled it ok? How much did you put in it? Quote Link to comment Share on other sites More sharing options...
1000dollabill Posted June 17, 2005 Report Share Posted June 17, 2005 Hi, I just filled my crankcase and it is pissing oil out the breather line. I think I filled it o.k. and the head gasket is o.k. maybe I'll just get new o-rings and change them to be sure. What does everyon think will cause this?? My coolant is also a little low at times but I never see it going out the overflow tube.?? Help!! 380773[/snapback] sounds like a clutch cover/water pump o-ring to me. trans fluid pissing seems as though it's probably thinning out and overflowing from mixing with the coolant. did you recently take the clutch cover off? if so you probably pinched the oring. take it off any way and check it. at least i would. later bill Quote Link to comment Share on other sites More sharing options...
