spurdy Posted June 10, 2005 Report Share Posted June 10, 2005 I have done a search on reed spacers and read everything on the forum. I'm using them for clearance purposes only with 35mm carbs. What difference is there in the position??? i.e. between reed and cylinder and between reed and carb. I have heard one for more top end and the other for bottom end. Does it make a difference? DOES ANYONE HAVE 1ST HAND EXPERIENCE??? I've been running them between reed and carb, what do you think? Quote Link to comment Share on other sites More sharing options...
stclark816 Posted June 10, 2005 Report Share Posted June 10, 2005 Ive heard theories the same as you have, but I honestly dont think there will ever be a noticeable difference. No, I havent ever run reed spacers so I guess I shouldnt be replying to this.. Just my thoughts. Quote Link to comment Share on other sites More sharing options...
spurdy Posted June 11, 2005 Author Report Share Posted June 11, 2005 Ive heard theories the same as you have, but I honestly dont think there will ever be a noticeable difference. No, I havent ever run reed spacers so I guess I shouldnt be replying to this.. Just my thoughts. 380307[/snapback] Thanks, any other takers? Quote Link to comment Share on other sites More sharing options...
duecebanshees Posted June 11, 2005 Report Share Posted June 11, 2005 Thanks, any other takers? 380347[/snapback] If you put the reed spacers between the reeds and the cylinder it will move the powerband more towards the lowend. If you put them between the carb and the reeds it will move it more towards the topend. My 2 cents from experience. Hope it helps. Quote Link to comment Share on other sites More sharing options...
Shee-Male Posted June 13, 2005 Report Share Posted June 13, 2005 If you put the reed spacers between the reeds and the cylinder it will move the powerband more towards the lowend. If you put them between the carb and the reeds it will move it more towards the topend. My 2 cents from experience. Hope it helps. 380352[/snapback] Other way around, with the spacer between the jug and the reed increases plenum volume, effectivly raising your powerband, also if you have them befor the reed you interupt flow since the reed opening is smaller then the spacer ID. I personally run a 1/2'' spacer @ the jug since a 2stroke twin loves to rev!, just gear accordingly. Quote Link to comment Share on other sites More sharing options...
