help quick.. stripped screws
i bought a new brake rotor and pads but the 4 allen head screws that hold the rear rotor onto the rotor hub are stripped and i can not get them out no matter what i try. I tryed heating them up, using vice grips, using a chizzle, and using a drill bit that fit perfectly but it sheared it into pieces. Any Ideas? Id feel pretty stupid if they were reversed threads..
380169[/snapback]
that really sucks don't it. i would imagine the heads are pretty messed up by now. i dont suppose you have access to a tig welder? i would try to weld a nut to the top of the bolt. the heat should break up the loctite or corrosion in the threads, and you will have a nut to put a socket on. sorry i couldnt give you a more simple answer. good luck
This is crude but it sounds like you're running out of options. If no access to a tig welder maybe try to smack the center with a steel hammer forcing the allen (or what was) to close up again. Now, drive, I think it is an M6, allen wrench 3/8 drive into the socket. You'll need and hammer driven impact driver at this point and your only going to get a couple of shots since the metal is already weakened, but smack the impact driver with a heavy dead blow and cross your fingers, if your lucky it will budge. Once it is moving yoiu could go back to the chisel method or whatever suits your fancy. Good luck! ;)
