onz Posted June 9, 2005 Report Posted June 9, 2005 i just bought an +4 swing arm for my banshee.when i recived it, it was shorter than i expected.can anyone tell me what the measurments are between a +4 and a stock swingarm so i can compare..let me know where you measured from Quote
John19 Posted June 9, 2005 Report Posted June 9, 2005 I would measure from the swingarm bolt to the rear axel hub. The center bolt on the hub that slides onto the axel. I can't think of the stock measurements off the top of my head, I can get you measurements from my -2 sometime tomorrow. So you can just add "2 inches to that. Quote
89Steeda Posted June 11, 2005 Report Posted June 11, 2005 My +4 is 22.5 inches. Thats from the center of the front pivot to the center of the rear axle. My new +8 is 26.5 inches. Just measured tonight. Quote
RNBRAD Posted June 17, 2005 Report Posted June 17, 2005 My +4 is 22.5 inches. Thats from the center of the front pivot to the center of the rear axle. My new +8 is 26.5 inches. Just measured tonight. 380455[/snapback] I get a 20.5"'. Are you measuring to the outside of the rear hub on the axle? Quote
89Steeda Posted June 17, 2005 Report Posted June 17, 2005 No I measured from the center of the swingarm bolt, to the center of the axle. Both swingers were side by side on the ground, bare with carriers installed. Quote
