is this common
wesw
motor yesterday started reving to the moon, then just died.
thought it was the carbs, clean them still wouldnt run.
with the filters off i could some what keep it running. the left carb was forcing air out the back side of the carb, the wrong way.
pulled the reeds and intake off, found this, the one was laying in the bottom of the intake.
anyone else had this problem??
also the other side the screws were loose so the other side probably was about to do it.
my advice to you all is check your v force reed and tighten the screws up banghead
378201[/snapback]
I havent seen any do like that but have seen some fray at the ends or tips of the reeds and crack. Wish i would of known you needed those before i sent your other parts out! :(
Let me if i can help!
jeff you must be a mind reader lol
actually i ordered a set of replacement reeds from dennis kirk lastnite
the screws just worked themselves loose i guess adn the reed vibrated to that crap
damnit
banghead
damnit
banghead
378228[/snapback]
Deniis Kirk? Blahhhh :flush: jk LOL
Call that # on your business card comin your way next time.
I agree with LTMX, might try some blue locktite.
i always use red loctite on those  .ive heard way to many horror storys of screws comin loose into the cylinders @ 11,000 rpms :(  not pretty or cheap :cry:
378298[/snapback]
wow f that yeah lock tite is being used to fix this mistake.
its bad engineering if you ask me :shootself:
I had the same problem with mine about a month ago. I broke one set, ordered replacement reeds, and broke them a week later. I called moto tassinari and told them about it, he said they have just developed a new reed petal for them that are a bit stronger. They told me to ship them my old reeds / cages and they would replace everything. A week later I had a BRAND NEW SET OF REEDS!!! I expected to get the old ones back... but nope, Brand new :headbang: Something you may want to look into. All i had to pay for was shipping
378321[/snapback]
yeah that's one of the reasons that they were re-engineered===Vforce3. the same thing happened to a buddy of mine, not a good feeling.
