waffles Posted June 3, 2005 Report Share Posted June 3, 2005 here is a list of mods im thinking over for my new banshee...so you experts let me know what to change... rocket pipes and silencers prodesign air filtermod with k=n with no lid vforce 2 reeds and valve?? bumped timing???how much and how? noss head with domes for 93 octane?????i ride at 3000 above sealevel.. mild porting from passion on the cylinders?????i need more info on this please...? ok that is the mods im considering....what should i change???? at first i wanted the toomey5 pipes because ofnot having to cut the plastic...around how many hp will i have after these mods??? Quote Link to comment Share on other sites More sharing options...
broke Posted June 3, 2005 Report Share Posted June 3, 2005 50ish depending on port work. Porting will make "ALL" the difference in the world, so it's hard to say. I always say my motors have 60HP. No matter what I build it will always be 60hp. Don't get too wrapped up in the numbers or pretty dyno charts. Dynos do one thing well, compare. As far as the number goes, who cares. But they will tell you if one pipe will out pull another on a given engine, or where the jetting needs to be tuned in a little more. Quote Link to comment Share on other sites More sharing options...
rocketboy Posted June 3, 2005 Report Share Posted June 3, 2005 if you plan to have passion porting, why dont you consult with jim (passion re) on here about his designs and what he recommends and estamates? Quote Link to comment Share on other sites More sharing options...
race-a-holic Posted June 4, 2005 Report Share Posted June 4, 2005 if you plan to have passion porting, why dont you consult with jim (passion re) on hereabout his designs and what he recommends and estamates? 377382[/snapback] It's important to get a builder you can trust.I've never used passion,but have heard good things about him.You should tell him what you plan on doing with your banshee,and he should have some suggestions.He'll most likely have a pipe he prefers.If you mostly ride trails,then you don't need a drag port. Quote Link to comment Share on other sites More sharing options...
strokrbanshee1 Posted June 4, 2005 Report Share Posted June 4, 2005 I have a motor that Jim at passion ported, It is set up to run on pump gas it runs great for all around riding and makes 65+ rear wheel h.p. Quote Link to comment Share on other sites More sharing options...
fastbanshee4u Posted June 4, 2005 Report Share Posted June 4, 2005 Yeah there right trust the builder unless he wants to empty your wallet.What kind of riding are you going to do.alot of people will tell you what they have,even though they have not tryed many combos.Good luck and yea it does not take a big bore to meke a shee fast. Quote Link to comment Share on other sites More sharing options...
Quadracer593 Posted June 4, 2005 Report Share Posted June 4, 2005 Banshees have 48 HP Stock so what stuff would probably get you to 55 or so? not sure Quote Link to comment Share on other sites More sharing options...
Banshee~ Posted June 4, 2005 Report Share Posted June 4, 2005 Banshees have 48 HP Stock so what stuff would probably get you to 55 or so? not sure 377498[/snapback] No, they have around 32-35 stock. The best thing you can do is call your engine builder up and tell him what your wanting out of your engine and he will hook you up with carbs, pipes, ect. Quote Link to comment Share on other sites More sharing options...
wesw Posted June 4, 2005 Report Share Posted June 4, 2005 jim has software that roughly tell him what the motor specs will make. he will give a pretty close estimate. it varies with the pipes from one to the other. just ask him. he is a nice guy and will answer your ? Quote Link to comment Share on other sites More sharing options...
broke Posted June 4, 2005 Report Share Posted June 4, 2005 Banshees have 48 HP Stock so what stuff would probably get you to 55 or so? not sure 377498[/snapback] You might want to recheck where ever you got that number from. Like Banshee~ said, they are more like the mid 30's. Quote Link to comment Share on other sites More sharing options...
ripper68 Posted June 4, 2005 Report Share Posted June 4, 2005 On my Certifiicate Of Orgin It State 47.5 Hp and this is what yamaha states it is, the Insurance companies use it when they quote you. Quote Link to comment Share on other sites More sharing options...
ke398 Posted June 4, 2005 Report Share Posted June 4, 2005 You might want to recheck where ever you got that number from. Like Banshee~ said, they are more like the mid 30's. 377621[/snapback] Not to take a stand one way or the other. The new issue of dirt wheels has the test of the first banshee and states it has 48 hp. Quote Link to comment Share on other sites More sharing options...
Banshee~ Posted June 5, 2005 Report Share Posted June 5, 2005 Not to take a stand one way or the other. The new issue of dirt wheels has the test of the first banshee and states it has 48 hp. 377732[/snapback] Dirtwheels is not worth a damn. Is that the magazine that said the 400ex was faster than the banshee when it first came out? Quote Link to comment Share on other sites More sharing options...
Stinger Posted June 5, 2005 Report Share Posted June 5, 2005 Maybe they are listing flywheel HP not rear wheel HP. I saw a bone stock Banshee dyno 32 wheel HP btw. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 5, 2005 Report Share Posted June 5, 2005 48 hp stock banshee?? Quote Link to comment Share on other sites More sharing options...
