FASTOYS Posted May 31, 2005 Report Share Posted May 31, 2005 Wow, Everybody is trying to discredit these pipes saying it is all hype and now you have the dyno sheets to prove it. I thin the real hype is with these "passion 25 port super duper motors" 80hp is aweful low for a 4mm. Hell i seen 350's on pump gas making more power. Maybe you should spend more time on your own work instead of bashing a pipe builder. You just proved your porting on a 4mm will only net 80 hp. 375543[/snapback] Damn, tough crowd! Wes, if you need to try some CPIs, you know who keeps them in stock , and in Kansas too! lol Well, now you do anyway. Quote Link to comment Share on other sites More sharing options...
wesw Posted May 31, 2005 Report Share Posted May 31, 2005 i would love to but im tapted out on spending money on dynoing. over 500 to do it about 3 times over several months. so maybe later, thanks jeff get back with me on that carb sync Quote Link to comment Share on other sites More sharing options...
PassionRE Posted May 31, 2005 Author Report Share Posted May 31, 2005 Wow, Everybody is trying to discredit these pipes saying it is all hype and now you have the dyno sheets to prove it. I thin the real hype is with these "passion 25 port super duper motors" 80hp is aweful low for a 4mm. Hell i seen 350's on pump gas making more power. Maybe you should spend more time on your own work instead of bashing a pipe builder. You just proved your porting on a 4mm will only net 80 hp. 375543[/snapback] Nobody's discrediting anything here my friend, Ive stated more than once that Rockets are a fine pipe and many will back me up on that. Several people are pulling big numbers on Rocket pipes. If you go to the main page youll see the words " The internets #1 Banshee resource"....my post was just an extension of what that means...information...take it or leave it. Considering that engine was built to a spec of 75hp@9700 rpm Id say the Shearers complimented it very well. Just because its a Passion 12 port...doesn't mean anything...12 ports are available from one spectrum to another in output. Dont think every motor I build is the highest HP motor available from me, not everyone wants that much power. BigWill has a 80+ hp gas 350 motor as we speak and thats not even the radical stuff....Jim Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 1, 2005 Report Share Posted June 1, 2005 Nobody's discrediting anything here my friend, Ive stated more than once that Rockets are a fine pipe and many will back me up on that. Several people are pulling big numbers on Rocket pipes. 375717[/snapback] ill agree with you jim!!! Quote Link to comment Share on other sites More sharing options...
wesw Posted June 3, 2005 Report Share Posted June 3, 2005 Wow, Everybody is trying to discredit these pipes saying it is all hype and now you have the dyno sheets to prove it. I thin the real hype is with these "passion 25 port super duper motors" 80hp is aweful low for a 4mm. Hell i seen 350's on pump gas making more power. Maybe you should spend more time on your own work instead of bashing a pipe builder. You just proved your porting on a 4mm will only net 80 hp. 375543[/snapback] still waiting for post of pic of dyno that you talked about Quote Link to comment Share on other sites More sharing options...
