joker149999 Posted May 28, 2005 Report Share Posted May 28, 2005 when you put new throttle cables on so you can get rid of the override on the carb s i was told you have too have the carbs machined out too put new idle adjuster screw's in or the bike won't run right once you get rid of the electroinc override bull shit, is that true? or can you just run the new cables and get rid of the electronic bull shit and not have too change the idler adjustment screws? Quote Link to comment Share on other sites More sharing options...
JA66 Posted May 28, 2005 Report Share Posted May 28, 2005 Theres already a spot for the idle screw but it doesnt go all the way through, so you have to finish drilling it (dont think its very far) then tap it, and put the idle screws in. I think you pretty much have to do that, i guess you could just mess with all the cable adjustments for the idle but that probably wouldnt be a good idea because they could move or a cable could slip and the carb would completely close off. Quote Link to comment Share on other sites More sharing options...
joker149999 Posted May 28, 2005 Author Report Share Posted May 28, 2005 (edited) So do you take out the old idle adjument screws then? or is there a different spot you have too put the new screw's? do you know what size drill bit and tap you need for these adjument screws? Edited May 28, 2005 by joker149999 Quote Link to comment Share on other sites More sharing options...
mybadbanshee Posted May 28, 2005 Report Share Posted May 28, 2005 the tors removal kit should come with a drill bit.the screws that are already in the carbs are NOT idle screws.the idle adjustment is on top of the tors system that you are eliminating.it is a real easy project,it only took me an hour or so from start to finish.VITOS sells a real good kit for about 50 bucks. Quote Link to comment Share on other sites More sharing options...
mybadbanshee Posted May 28, 2005 Report Share Posted May 28, 2005 the existing screws you are talking about in the carbs are air/fuel screws.do NOT take them out. Quote Link to comment Share on other sites More sharing options...
joker149999 Posted May 28, 2005 Author Report Share Posted May 28, 2005 Well what size drill bit do you need and tap? to drill and tap the idle screw holes out? does anyone know? also do you even have too change them screws? Quote Link to comment Share on other sites More sharing options...
dajogejr Posted May 29, 2005 Report Share Posted May 29, 2005 Buy the kit. Motion pro, Toomey and Vitos all sell them. It comes with two brass bullet nosed screws, the correct drill bit AND tap. You're NOT changing any screws. You're simply finishing out a hold that needs to be all the way clear, on the outside of each carb. As said, it's an hour or so project start to finish. Here is Toomey's link to instructions, but...no pics. http://www.toomey.com/html/ik_install.htm Or...check here. About 1/4 way down, you can see the idle kit for a shee. It's 24.95. Comes with all you need. http://www.vitosperformance.net/BANSHEE.HTM Quote Link to comment Share on other sites More sharing options...
joker149999 Posted May 29, 2005 Author Report Share Posted May 29, 2005 I went to the website for the idler adj. screw's by toomie and it say's you need a number 6 drill bit, that would be a 1/4 inch bit correct? Quote Link to comment Share on other sites More sharing options...
dajogejr Posted May 30, 2005 Report Share Posted May 30, 2005 Dunno...Might want to call a machine shop or hit the local hardware store. I bought the kit to ease my worries Quote Link to comment Share on other sites More sharing options...
