bigboybanshee Posted May 25, 2005 Report Share Posted May 25, 2005 I'm about to be building a drag engine and was wondering what kind of compression you guys are running in your setups? What size domes are you running (cut/standard) ? I know that porting will lower your overall comression but am not sure if you should compensate that loss by running a smaller dome....I also hear that running really high compression will reduce top end performance; is that true? Sorry for so many questions, just want to be sure I build it right Quote Link to comment Share on other sites More sharing options...
ellison445 Posted May 25, 2005 Report Share Posted May 25, 2005 I happen to be in the same boat as you so I am curious as well What kind of pipes did you end up going with? I'm about to be building a drag engine and was wondering what kind of compression you guys are running in your setups? What size domes are you running (cut/standard) ? I know that porting will lower your overall comression but am not sure if you should compensate that loss by running a smaller dome....I also hear that running really high compression will reduce top end performance; is that true? Sorry for so many questions, just want to be sure I build it right 373689[/snapback] Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted May 25, 2005 Author Report Share Posted May 25, 2005 I bought these pipes... Quote Link to comment Share on other sites More sharing options...
ellison445 Posted May 25, 2005 Report Share Posted May 25, 2005 ahhhhh Better hold on for your fucking life LOL I bought these pipes... 373696[/snapback] Quote Link to comment Share on other sites More sharing options...
rzcolobanshee Posted May 25, 2005 Report Share Posted May 25, 2005 Small domes will kill top end performance, don't worry about compression numbers, they will only tell you if you need a rebuild. Compression ratio and squish band are key. I've done a lot of research on this lately, I used to run 15cc domes and now I know why I had no top end. You should have your builder cut the domes for your application. Quote Link to comment Share on other sites More sharing options...
Big Blue Posted May 25, 2005 Report Share Posted May 25, 2005 I'm about to be building a drag engine and was wondering what kind of compression you guys are running in your setups? What size domes are you running (cut/standard) ? I know that porting will lower your overall comression but am not sure if you should compensate that loss by running a smaller dome....I also hear that running really high compression will reduce top end performance; is that true? Sorry for so many questions, just want to be sure I build it right 373689[/snapback] Mine was running around 175-180lbs with 18cc domes when you rode it. Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted May 25, 2005 Author Report Share Posted May 25, 2005 Mine was running around 175-180lbs with 18cc domes when you rode it. 373711[/snapback] Were the 18cc domes cut or standard? If cut, who cut them? Thanks for the help guys Quote Link to comment Share on other sites More sharing options...
Big Blue Posted May 25, 2005 Report Share Posted May 25, 2005 Were the 18cc domes cut or standard? If cut, who cut them? Thanks for the help guys 373713[/snapback] They are the ones i ordered from noss after i took the cut 20cc ones out. Quote Link to comment Share on other sites More sharing options...
bigboybanshee Posted May 25, 2005 Author Report Share Posted May 25, 2005 They are the ones i ordered from noss after i took the cut 20cc ones out. 373726[/snapback] What kind of difference did you notice switching from the 20cc to the 18cc domes? I mean, did you notice more overall power, more low end, more torque, no difference, etc.? Quote Link to comment Share on other sites More sharing options...
Big Blue Posted May 26, 2005 Report Share Posted May 26, 2005 I noticed a big difference everywhere, to me it felt like a totally different bike after switching domes. Quote Link to comment Share on other sites More sharing options...
