jeepman380 Posted May 25, 2005 Report Share Posted May 25, 2005 Just curious of what type of chain lube everyone uses. I've tried alot of them but I can't seem to find a really good one. They either sling off or catch dirt. What has worked well for y'all? Quote Link to comment Share on other sites More sharing options...
bansheefreestyler Posted May 25, 2005 Report Share Posted May 25, 2005 I use maxima chain wax. seems to work pretty good. Quote Link to comment Share on other sites More sharing options...
racer Posted May 25, 2005 Report Share Posted May 25, 2005 Belray chain saver. you can't cut that stuff off with a knife. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted May 25, 2005 Report Share Posted May 25, 2005 i use fast orange..makes you go fast and smells good! Quote Link to comment Share on other sites More sharing options...
Banshee17Racing Posted May 25, 2005 Report Share Posted May 25, 2005 Use to use ChainGuard....moved up to PJ1 Chain Lube Quote Link to comment Share on other sites More sharing options...
bansheeryder_69 Posted May 25, 2005 Report Share Posted May 25, 2005 Suzuki chain lube from when I had my 125 seems to work for me Quote Link to comment Share on other sites More sharing options...
MILO Posted May 25, 2005 Report Share Posted May 25, 2005 Belray chain saver. you can't cut that stuff off with a knife. 373559[/snapback] yep. Quote Link to comment Share on other sites More sharing options...
RNBRAD Posted May 25, 2005 Report Share Posted May 25, 2005 I don't use anything other than wd-40 and a rag to occasionally clean the chain. Anything else is just too messy. Quote Link to comment Share on other sites More sharing options...
redcell43 Posted May 25, 2005 Report Share Posted May 25, 2005 I don't use anything other than wd-40 and a rag to occasionally clean the chain. Anything else is just too messy. 373679[/snapback] i hated dealing with the mess chain wax made, so now i just use WD-40 and it works great in sand and dirt. Quote Link to comment Share on other sites More sharing options...
SICK BOY Posted May 25, 2005 Report Share Posted May 25, 2005 Belray chain saver. you can't cut that stuff off with a knife. 373559[/snapback] Same here Quote Link to comment Share on other sites More sharing options...
Brian060 Posted May 25, 2005 Report Share Posted May 25, 2005 Belray chain saver. you can't cut that stuff off with a knife. 373559[/snapback] me too!! Quote Link to comment Share on other sites More sharing options...
Slammin Full Bore Posted May 25, 2005 Report Share Posted May 25, 2005 I use yamalube Quote Link to comment Share on other sites More sharing options...
rocketboy Posted May 25, 2005 Report Share Posted May 25, 2005 wd40 is 60% kerosene and is excellent for o ring chains on 2 strokes Quote Link to comment Share on other sites More sharing options...
SANDSTAR Posted May 26, 2005 Report Share Posted May 26, 2005 I use dry graphite spray lube from napa. Sprays on and dries on contact. Will not fling, sand can't stick. Looks / feels like teflon. Quote Link to comment Share on other sites More sharing options...
BdBanshee Posted May 26, 2005 Report Share Posted May 26, 2005 I also use WD40, if it was good enough for Dean Sundahl to use on his Baja winning Banshee, it's good enough for mine. Quote Link to comment Share on other sites More sharing options...
