banshee x Posted May 25, 2005 Report Posted May 25, 2005 i asked a similar question about what carb to run on the mods forum, i'm not sure if i should go with 33's or 35's and whats the difference between pwk and air stryker? if i buy these from pro-flo.com(because the are cheap)will i just be able to order both carbs individually. what about using the choke(do u just use one side?) thanks putting in a 4mil crank and dropped my cylinders off for a dune/drag port need to order some carbs this week thanks any help would be great!!!! Quote
badassbanshee479 Posted June 22, 2005 Report Posted June 22, 2005 I bought my 35mm air strykers from jeff over at fast, he has everything you need to install them, air filters, intake boots, pre-filters, etc.... you can order as much as you want from him or as little as you want, his prices were also cheaper then pro-flow. as far as the choke goes on my banshee I only use one side and it fires right up. good luck Quote
banshee x Posted June 22, 2005 Author Report Posted June 22, 2005 thanks unfortionally i bought then from pro flow didnt know jeff sold carbs but thanks Quote
fixitrod Posted June 22, 2005 Report Posted June 22, 2005 airstrykers have what they call a quad vent. Here's what Keihin has to say about them. Quad Vents: Eliminates post jump bog-down from fuel plugged vent passages PWK Air Strikers: Directs air to main nozzle for improved signal and throttle response. Quote
