stu Posted May 24, 2005 Report Share Posted May 24, 2005 anyone here run a lonestar swaybar? doesnt even have to be on a shee any bike will do! Im trying to get some pics as i have to fab up a couple parts to make mine fit and work nicely. Lonestar themselves told me the sway bar fitted to the top shock mounts rather than the a-arm mounting point, which seems a little weird?! stu Quote Link to comment Share on other sites More sharing options...
icrashmore13 Posted June 20, 2005 Report Share Posted June 20, 2005 anyone here run a lonestar swaybar? doesnt even have to be on a shee any bike will do! Im trying to get some pics as i have to fab up a couple parts to make mine fit and work nicely. Lonestar themselves told me the sway bar fitted to the top shock mounts rather than the a-arm mounting point, which seems a little weird?! stu 373272[/snapback] new member want to post a pic give some info Quote Link to comment Share on other sites More sharing options...
Proquad101 Posted June 21, 2005 Report Share Posted June 21, 2005 I use the dura blue sway-bar. Quote Link to comment Share on other sites More sharing options...
stu Posted June 21, 2005 Author Report Share Posted June 21, 2005 all sorted now cheers guys.....just fab'd up some new parts and its good to go, just in the process of making a lowering kit and flat trakkin here we come!! stu Quote Link to comment Share on other sites More sharing options...
crank67 Posted December 6, 2005 Report Share Posted December 6, 2005 anyone here run a lonestar swaybar? doesnt even have to be on a shee any bike will do! Im trying to get some pics as i have to fab up a couple parts to make mine fit and work nicely. Lonestar themselves told me the sway bar fitted to the top shock mounts rather than the a-arm mounting point, which seems a little weird?! stu 373272[/snapback] Quote Link to comment Share on other sites More sharing options...
370banshee Posted December 6, 2005 Report Share Posted December 6, 2005 how you lowering the front???? a durablue kit won't get you near low enough.... and a simple lowering strut for the back will not be low enough either.... Quote Link to comment Share on other sites More sharing options...
stu Posted December 12, 2005 Author Report Share Posted December 12, 2005 hey there, I got some 300ex shocks for the front off ebay. that should drop the front enough. As for the rear im not sure yet, ill have to fab a lowering bracket as i run a no-linkage swingarm and all the lowring kits ive seen use the rear shock linkage. stu Quote Link to comment Share on other sites More sharing options...
370banshee Posted December 17, 2005 Report Share Posted December 17, 2005 try running a shorter rear shock.. Quote Link to comment Share on other sites More sharing options...
stu Posted December 17, 2005 Author Report Share Posted December 17, 2005 try running a shorter rear shock.. 449093[/snapback] if i find a cheap one i will. but its got to have a pretty stiff spring on her. maybe a streetbike shoick would work?? Ive got an old cbr shocker i could play with to make fit stu Quote Link to comment Share on other sites More sharing options...
370banshee Posted December 29, 2005 Report Share Posted December 29, 2005 well i'll give up the secret that was told to me... use a YSR50 rear shock.. then you have to weld a new shock mounts onto the swinger.. Quote Link to comment Share on other sites More sharing options...
