a-arms what brand?
yfz450ss
this may sound a little over board to some but do they make a +1out +2 forward
or even +3 forward. im going to run elka's with resi's and i need to go as forward as posible.if i have too i might even go plus 2 out to get the front tires as forward as posible.is this also considered long travel?
oh its for a banshee .
371535[/snapback]
+ 3 forward will handle horribly will push front end all over the place
the ultimate ride would be LT banshee a arms with quad rate shocks.
i agree with sand dragon, +3 sounds like it would throw the whole geometry of the bike off into left field, i't stick with a lt setup
371657[/snapback]
what are the specs on the lt set-up ?
i mainly drag race and dune ride some trail but not as much.
im running alot of motor and dont want to loose my hp to a swing arm
371671[/snapback]
got what ever u need, +2, or +3 a arms both use a 19" shock and are quad rate. will give you around 13" of travel and a much more progressive ride then any +2 arm with 1" shcks can give
