bansheeryder21 Posted May 14, 2005 Report Share Posted May 14, 2005 Does anyone have reed spacers on their banshee? I was thinking about putting some on because they are cheap but don't know how much of a power increase it will give me. Is it worth it, or should I just do new reeds with spacers or new reeds without spacers or just spacers??? Some advice please? Quote Link to comment Share on other sites More sharing options...
bogart Posted May 14, 2005 Report Share Posted May 14, 2005 Does anyone have reed spacers on their banshee? I was thinking about putting some on because they are cheap but don't know how much of a power increase it will give me. Is it worth it, or should I just do new reeds with spacers or new reeds without spacers or just spacers??? Some advice please? 369157[/snapback] no power increase.there to be used with bigger carbs so the bottom of the bowl wont hit the shifter mechanism. Quote Link to comment Share on other sites More sharing options...
itsaripper Posted May 14, 2005 Report Share Posted May 14, 2005 The spacer will give the reeds more time to open and close if you put them inbetween the reed cage and the motor. That should give you some more bottom end. Not gobs just some. Quote Link to comment Share on other sites More sharing options...
wayfst Posted May 14, 2005 Report Share Posted May 14, 2005 everytime used reed spacers i lost my bottom end and gained NOTHING anywhere else. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted May 15, 2005 Report Share Posted May 15, 2005 i had a friend get them he said no power increase but he got bigger carbs and they were hittin somthing and it just gave him more space Quote Link to comment Share on other sites More sharing options...
quick-z Posted May 16, 2005 Report Share Posted May 16, 2005 I tryed them and took them off not worth anything to me Quote Link to comment Share on other sites More sharing options...
RATBIKE0130 Posted May 16, 2005 Report Share Posted May 16, 2005 The spacer will give the reeds more time to open and close if you put them inbetween the reed cage and the motor. That should give you some more bottom end. Not gobs just some. 369199[/snapback] Can you explain to me how adding reed spacers can cause the reeds to stay open longer? Please go into detail because I just can't picture how this could happen. Quote Link to comment Share on other sites More sharing options...
RATBIKE0130 Posted May 20, 2005 Report Share Posted May 20, 2005 itsaripper Are you going to tell us how this works? Quote Link to comment Share on other sites More sharing options...
