Got a Reassembly problem
heres the deal I been coming up from a rebuild, when i got to the clutch last night i was noticing clymer has a picture of a spacer that goes in between the clutch boss and the clutch basket I kept everything together in my clutch just slid it all off, but when i was puting it back together i noticed that i didnt have one but i have 2 spacers niether of which looks like they go on there ,they both have play on the shaft, does anyone know what im talking about and or have a pic, or can tell me where to get one?
My clutch basket is ready to come off in the morning. (Just need to find my 27mm socket!). ... I'll take a pic of what's behind there if you still need it tomorrow.
I think what you're talking about that you have are 'thrust plates'. ... The order of removal in my 'Yamaha Service Manual' is:
Remove:
- Clutch boss
- Thrust plate
- Clutch housing
- Spacer
- Thrust plate
Hope that helps. ;)
Edit: From the pic in this manual, the thrust plates look like washers and the spacer is quite a substantial piece of steel. ... 1" - 1 1/2 maybe. :shrugani:
Rare.
Edited by Rare Scottish Tree Badger
#1 and 4 are the thick thrust washers/spacers. One goes behind the clutch basket and the other one goes on after the basket before the inner clutch boss/hub. I have some if you need one shoot me a pm!
P.S. Make sure they dont have grooves worn in them and make sure to oil them up before installation.
369192[/snapback]
The #4 you show there looks like what I have out there but there is play on the shaft, i'm going to go check it all out and see If I need it thanks. :cheers:
What's the torque spec for putting the flywheel back on?
369278[/snapback]
Make sure to use locktite on the flywheel nut !
