400rednEX Posted May 12, 2005 Report Share Posted May 12, 2005 how do these intake setups compare to each other? Quote Link to comment Share on other sites More sharing options...
sredish Posted May 12, 2005 Report Share Posted May 12, 2005 Trinity works with stock airbox setup, no mods necessary. The Graydon requires you to move the airbox back and/or mod the box and stuff. Kind of a PITA from what I've heard. Some feel they have the same power output, but others say they feel the Graydon may have a slight bit more torque, don't really know and neither has been really tested. You can search for Graydon, 2-1, single carb, and any combination you can think of and will come up with LOADS of info. There was a big Graydon thread a while back, just do some tricky searching and you'll have plenty of info. Scott Quote Link to comment Share on other sites More sharing options...
brock_fuzzy_69 Posted May 13, 2005 Report Share Posted May 13, 2005 yeah if you search under my posted topics you should see a graydon question similar to what you have above Quote Link to comment Share on other sites More sharing options...
cgamla Posted May 15, 2005 Report Share Posted May 15, 2005 Comment on that airbox thing. I have a trinity 33 cv set up with the airbox adapter and I'll be danged if I can get the thing to line up without cutting on my airbox mounts. Quote Link to comment Share on other sites More sharing options...
sredish Posted May 15, 2005 Report Share Posted May 15, 2005 Comment on that airbox thing. I have a trinity 33 cv set up with the airbox adapter and I'll be danged if I can get the thing to line up without cutting on my airbox mounts. 369332[/snapback] never had a problem hooking up the trinity setup to a stock airbox. I usually mount the manifold with the rubber boot to the cylinders and put the carb and the airbox together then slide the airbox/carb into the rubber boot and bolt the airbox carb. You can just cut the front airbox mounts off if you want, it'll make it easier. Quote Link to comment Share on other sites More sharing options...
cgamla Posted June 5, 2005 Report Share Posted June 5, 2005 good point but then I would have to listen to all that damn intake noise that I hear every time I put that air box on. Quote Link to comment Share on other sites More sharing options...
