Badshee22 Posted May 11, 2005 Report Share Posted May 11, 2005 (edited) I AM EXPERIENCING SOME HARD TO SHIFT PROBS, I HAVE ALL BOLT ON PARTS AND PORTING DONE. I AM INSTALLING A TUDOR SHIFT PRO KIT AND AM WONDERING IF I SHOULD MOD THE SHIFT STAR AND DO THE SHIFT KIT? IS THERE ANYTHING ELSE I SHOULD DO WHILE I AM IN THERE? 2 THINGS I HAVN'T DONE IS LIGHTEN FLYWHEEL AND TIMING ADVANCE. Edited May 11, 2005 by Badshee22 Quote Link to comment Share on other sites More sharing options...
dajogejr Posted May 11, 2005 Report Share Posted May 11, 2005 Shift Star, most definately. I just went on an all day Ride Saturday for the first time with my modded star, bit, big difference. Also...get the stator timing plate and get the flywheel lightened. All mods I put in last Friday and rode with on Saturday...I couldn't be happier!! There are plenty here that can do that for you...Boonman did mine, and he's a helluva fella. Quote Link to comment Share on other sites More sharing options...
ssanddemon Posted May 12, 2005 Report Share Posted May 12, 2005 Check out your clutch basket & hub. Make sure you haven't got grooves that are hanging up the steels or fibers- It's a pretty common problem. Quote Link to comment Share on other sites More sharing options...
fastbanshee4u Posted May 12, 2005 Report Share Posted May 12, 2005 After you install the shift parts,adjust the up and down play for the shifter.Get it centered. Quote Link to comment Share on other sites More sharing options...
MDS2106 Posted May 12, 2005 Report Share Posted May 12, 2005 (edited) if you run both ,hitting large bumps can cause your banshee to shift with out you wanting it to, the shift pro says you can run both but i wouldn't,if you do decide to try both of them don't get pissed when you have to pull that bitch back apart to remove the modded shift star, be sure and check the egg shaped bolt that adjusts the shift rod, if it is wore down it will not allow you to get the adjustment you need on the shift shaft Edited May 12, 2005 by MDS2106 Quote Link to comment Share on other sites More sharing options...
Badshee22 Posted May 12, 2005 Author Report Share Posted May 12, 2005 if you run both ,hitting large bumps can cause your banshee to shift with out you wanting it to, the shift pro says you can run both but i wouldn't,if you do decide to try both of them don't get pissed when you have to pull that bitch back apart to remove the modded shift star, be sure and check the egg shaped bolt that adjusts the shift rod, if it is wore down it will not allow you to get the adjustment you need on the shift shaft 368326[/snapback] thanks i appreciate the help Quote Link to comment Share on other sites More sharing options...
MDS2106 Posted May 12, 2005 Report Share Posted May 12, 2005 no problem, let us know how it shifts Quote Link to comment Share on other sites More sharing options...
