Rear spring color
My replacement standard used rear shock arrived today. It has a yellow spring. ... Is there any significance to this, as my 2001 bike has a white spring? Another thing that's different is that the adjuster for compression is metal, whereas the one on my bike is a black plastic adjuster.
Rare.
if you dont like the spring color just have it PCed. otherwise they are all the same i believe, just different colors for different years.
368729[/snapback]
I wasn't bothered about the color, I just wanted to try and date it. ... I bought it on eBay as 'Like New' and it's worse than the one I already have!
Rebound (bottom adjuster):
My one has 7 clicks from tight (at the top) before it just spins freely all the way to the bottom. ... This one only has 5 clicks before it does the same.
They're supposed to have 20 clicks from tight at the top, to tight at the bottom. Is that right?
Rare.
  • 1 month later...
yea thats right, sounds like you got ripped, maybe between the 2 shocks you can rebuild one stocker, or send yours out to elka or works or a shock company and get it made for your weight.
369204[/snapback]
I got a full refund (less shipping) and got to keep the shock. So I guess I will try to make one good one out of the two. ... And I'll check out having one of them sent out for a rebuild.
Anyone know of anywhere in the UK that does shock rebuilding?
Rare.
Rare.
384105[/snapback]
Call Barry at Raceserve suspension.He just rebuilt both my front Reigers.Did a great job and isn't too expensive.Pm me if you want the no.
P.s. Hows the Banshee running now?
Edited by neilgf
  • 2 weeks later...
