DigglerD Posted May 4, 2005 Report Share Posted May 4, 2005 My Banshee came with a single K&N cone filter on it and I have no idea what part number it is so I cant order a prefilter. I get sand in the thing all the time and need to get one ASAP. Anybody know a part# for the filter I need? One I get a prefilter, can I remove my air box (the lid is already off). Quote Link to comment Share on other sites More sharing options...
03bansheeLE Posted May 4, 2005 Report Share Posted May 4, 2005 My Banshee came with a single K&N cone filter on it and I have no idea what part number it is so I cant order a prefilter. I get sand in the thing all the time and need to get one ASAP. Anybody know a part# for the filter I need? One I get a prefilter, can I remove my air box (the lid is already off). 364554[/snapback] yes, you can remove the precharger but make sure you dont ride in water or mud cause that will ruin the filter. Also make sure you get an adaptor plater for the filter or screw it onto the plastic runners that go to the carbs. I have a precharger on mine but im not gonna take the airbox off cause i ride in water and mud n' shit, ill just take the lid off. I dont have the part number but im sure if you have a picture of the precharger then you can make sure it fits, or just post the pic and ill tell you if it is it. Hope this helps, Darren Quote Link to comment Share on other sites More sharing options...
DigglerD Posted May 4, 2005 Author Report Share Posted May 4, 2005 yes, you can remove the precharger but make sure you dont ride in water or mud cause that will ruin the filter. Also make sure you get an adaptor plater for the filter or screw it onto the plastic runners that go to the carbs. I have a precharger on mine but im not gonna take the airbox off cause i ride in water and mud n' shit, ill just take the lid off. I dont have the part number but im sure if you have a picture of the precharger then you can make sure it fits, or just post the pic and ill tell you if it is it. Hope this helps, Darren 364568[/snapback] Thanks Darren unfortunately you gave all the answers to the wrong questions that I already have. My question was not that I had a prefilter and can I take it off. It was that I need a prefilter, what's the part# and once I get one, can I take the airbox off. The K&N is already mounted, the adapter plate is already on... do you run the single cone? If so what was the part# for the pre-filter? Quote Link to comment Share on other sites More sharing options...
03bansheeLE Posted May 5, 2005 Report Share Posted May 5, 2005 let me know if this is the filter you have. copy link into adress bar for filter: http://www.knfilters.com/search/product.aspx?Prod=YA-3502 part number: YA-3502 the precharger for that filter: http://www.knfilters.com/search/product.aspx?Prod=YA-3502PK part number: YA-3502PK I am sorry, i meant that you can take the airbox off but dont ride in wet conditions. I have the single cone filter and pics are attached. Quote Link to comment Share on other sites More sharing options...
03bansheeLE Posted May 5, 2005 Report Share Posted May 5, 2005 i researched for 2003 banshee cause thats wut i got but im pretty sure all the years can take the same k&n filter Quote Link to comment Share on other sites More sharing options...
DigglerD Posted May 5, 2005 Author Report Share Posted May 5, 2005 Thats it! Do they have a foam one? Quote Link to comment Share on other sites More sharing options...
03bansheeLE Posted May 5, 2005 Report Share Posted May 5, 2005 a foam wut? filter? Quote Link to comment Share on other sites More sharing options...
rider22 Posted May 5, 2005 Report Share Posted May 5, 2005 Thats it! Do they have a foam one? If you are sucking sand, you MUST get a foam pre filter. The nylon type like outerwears, will not help keep out the fine sand. Quote Link to comment Share on other sites More sharing options...
DigglerD Posted May 5, 2005 Author Report Share Posted May 5, 2005 Thats it! Do they have a foam one? If you are sucking sand, you MUST get a foam pre filter. The nylon type like outerwears, will not help keep out the fine sand. 364609[/snapback] Cool, where do I get one? Part number? Quote Link to comment Share on other sites More sharing options...
Wallynut Posted May 5, 2005 Report Share Posted May 5, 2005 I think that if you are using the pro-flow with a K&N, you will need a different adaptor to run a foam filter. I don't think that UNI or others make a filter that size that you could "force" it to fit, so to speak. Quote Link to comment Share on other sites More sharing options...
MDS2106 Posted May 5, 2005 Report Share Posted May 5, 2005 it seems like someone would make a foam pre-filter that would fit over the k&n, i didn't realize how much shit the K&N lets thru, until i tore down for rebuid and ran my fingers up into the carb boots,very fine fine sand stuck in oil Quote Link to comment Share on other sites More sharing options...
Oilsmoke Posted May 5, 2005 Report Share Posted May 5, 2005 I don't see many foam filters at the dune. K&N's with prefilter or outwears. Quote Link to comment Share on other sites More sharing options...
