J.J. Posted June 21, 2005 Report Share Posted June 21, 2005 To eliminate bumpsteer, both the centre points of the arc and the radius of the arc travelled by the tie rod and the wheel must co-incide, through the complete range of suspension travel. This is not possible to achieve on a stock framed banshee due to the location of the a-arm hinge points on the frame. No matter what a-arms you throw at it... This has been discussed in detail many times on this forum, hence Meat's comment. That being said, I would love to have one of those LT set-ups bolted to my frame...If only I could afford it... Quote Link to comment Share on other sites More sharing options...
racer Posted June 21, 2005 Report Share Posted June 21, 2005 To eliminate bumpsteer, both the centre points of the arc and the radius of the arc travelled by the tie rod and the wheel must co-incide, through the complete range of suspension travel.This is not possible to achieve on a stock framed banshee due to the location of the a-arm hinge points on the frame. No matter what a-arms you throw at it... This has been discussed in detail many times on this forum, hence Meat's comment. That being said, I would love to have one of those LT set-ups bolted to my frame...If only I could afford it... 384308[/snapback] explained in a fashion only an engineer could love. however, couldnt you change that with an aftermarket sterring stem? Quote Link to comment Share on other sites More sharing options...
MonkeyBoy Posted June 21, 2005 Report Share Posted June 21, 2005 JJ, you can minimize the effect, but not totally remove it. But that is the key, minimization. Especially as you run more wheel travel, it becomes inevitable. I would rather not badmouth the suspension I have, just promote what is right. You would be surprised by the names of some companies that sell poor geometry, strength, and materials to people. Be informed, and ask questions. Sanddragon had nothing to hide, and responded as such. Quote Link to comment Share on other sites More sharing options...
J.J. Posted June 22, 2005 Report Share Posted June 22, 2005 however, couldnt you change that with an aftermarket sterring stem? Yep, I remember you parallel linkage steering set-up, still waiting for that drawing though... JJ, you can minimize the effect, but not totally remove it. But that is the key, minimization. Especially as you run more wheel travel, it becomes inevitable. I would rather not badmouth the suspension I have, just promote what is right. You would be surprised by the names of some companies that sell poor geometry, strength, and materials to people. Be informed, and ask questions. Sanddragon had nothing to hide, and responded as such. MonkeyBoy, I have absolutely nothing against anyones LT a-arms, but I'm enough of an engineer to recognise the limitations of the stock frame, as I'm sure you do as well. Quote Link to comment Share on other sites More sharing options...
racer Posted June 22, 2005 Report Share Posted June 22, 2005 Yep, I remember you parallel linkage steering set-up, still waiting for that drawing though... 384396[/snapback] once i figure out paint.............................. ill do it one of these days. Quote Link to comment Share on other sites More sharing options...
bansheefreestyler Posted June 22, 2005 Report Share Posted June 22, 2005 hey sanddraggon how much for a set? and is that with or without shocks? what kind of deals you give? Quote Link to comment Share on other sites More sharing options...
MonkeyBoy Posted June 25, 2005 Report Share Posted June 25, 2005 Yep, I remember you parallel linkage steering set-up, still waiting for that drawing though... MonkeyBoy, I have absolutely nothing against anyones LT a-arms, but I'm enough of an engineer to recognise the limitations of the stock frame, as I'm sure you do as well. 384396[/snapback] Yes, unfortunately I do. Does anyone know if a YFZ frame would fit a Banshee motor? We can work out the details, but that is the best handling chassis out there right now. And it happens to be Yami I would like to also see if the swingarm and linkage from an 06 YFZ will bolt up to a Banshee. Imagine a alum swingarm and a round housing. Don't worry about strength, they hold up. Quote Link to comment Share on other sites More sharing options...
racer Posted June 25, 2005 Report Share Posted June 25, 2005 I would like to also see if the swingarm and linkage from an 06 YFZ will bolt up to a Banshee. Imagine a alum swingarm and a round housing. Don't worry about strength, they hold up. 385678[/snapback] probably not, we arent that lucky. but with some washers and a die grinder............... Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted June 26, 2005 Report Share Posted June 26, 2005 Does anyone know if a YFZ frame would fit a Banshee motor? 385678[/snapback] someone give me a frame and motor and ill make it happen...seems i have a problem with making quads yamaha should have produced... Quote Link to comment Share on other sites More sharing options...
MonkeyBoy Posted June 27, 2005 Report Share Posted June 27, 2005 Problem with the YFZ swingarm isn't the swinger itself, but the angle of the rear shock. The shock is almost straight up on the YFZ, laid much more down on the Banshee. Quote Link to comment Share on other sites More sharing options...
BenBB Posted June 30, 2005 Report Share Posted June 30, 2005 someone give me a frame and motor and ill make it happen...seems i have a problem with making quads yamaha should have produced... 385848[/snapback] I'm still dreamin' about mine with a long travel 250R frame and an RZ motor...I got dibs loco, just might take me 5 years to get there hahaha Quote Link to comment Share on other sites More sharing options...
BrianEb Posted June 30, 2005 Report Share Posted June 30, 2005 I have alot to learn I thought LT arms were the way to go on all ATV's Now I'm lost once again I've been saving my money for either Jansens, ATV Fourplay, Eyeball Eng. LT arms. But know I read that the Banshee Frame Geometry does not support LT arms well. The long travels create bad bump steer (whatever bump steer is). Should I just get a set of Chrome +2 +1 Quicksand Arms with some wheel spacers. Someone please explain this to me like a six year old so I can understand better and make a smart choice. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted July 1, 2005 Report Share Posted July 1, 2005 I'm still dreamin' about mine with a long travel 250R frame and an RZ motor...I got dibs loco, just might take me 5 years to get there hahaha 387227[/snapback] ben, you get the frame and motor and ship it my way. itll be a good winter project...youll have the fastest 250r around.. Quote Link to comment Share on other sites More sharing options...
RNBRAD Posted July 2, 2005 Report Share Posted July 2, 2005 Brings back memories. Quote Link to comment Share on other sites More sharing options...
Meat Posted July 3, 2005 Report Share Posted July 3, 2005 (edited) Edited July 3, 2005 by Meat Quote Link to comment Share on other sites More sharing options...
