dajogejr Posted January 18, 2007 Report Share Posted January 18, 2007 pull the tops off the carbs get some scotch brite pad, and kinda sand the bottom edge of the slide. i has little small knicks and stuff that snag the bore body. just smoothe it up some it works great Exactly what I'd do. I'd think with two stroke gas and oil, the grease would get washed off after a short time. Scotchbrite the whole slide with a very fine pad, clean it with soap and water, dry completely, and put it back together. Also check your cable for breaks, frays, etc. Do you have your TORS removed? Using the proper cable? And did you use the idle removal kits? Quote Link to comment Share on other sites More sharing options...
DADEBOYRACER101 Posted January 18, 2007 Report Share Posted January 18, 2007 the little thing in the throttle take the top of and see if it stick Quote Link to comment Share on other sites More sharing options...
