crbanshee Posted April 28, 2005 Report Share Posted April 28, 2005 ok i see more and more yfz 450 shocks on banshee's but what i need to find out is will the a arms from a 450 fit on the shee?? has any one tryed? does it fit and more important is if they do work on the shee how is the ride after using 450 pars on it??? Quote Link to comment Share on other sites More sharing options...
stclark816 Posted April 29, 2005 Report Share Posted April 29, 2005 I pondered that idea for a while. A member on here (SVTJAMES) put 450 a arms on his banshee. He had a local shop modify his frame to have it done. So no, they dont just bolt right up. I got a pic of his banshee I think... Let me check Quote Link to comment Share on other sites More sharing options...
stclark816 Posted April 29, 2005 Report Share Posted April 29, 2005 Here Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted April 29, 2005 Report Share Posted April 29, 2005 the uppers will bolt right on, the lower arm would have to be modified, or youd have to modify the frame. i messed with it for a while on my cr500 banshee and decided that it wasnt worth it. Quote Link to comment Share on other sites More sharing options...
sanddragon2004 Posted April 29, 2005 Report Share Posted April 29, 2005 the uppers will bolt right on, the lower arm would have to be modified, or youd have to modify the frame. i messed with it for a while on my cr500 banshee and decided that it wasnt worth it. 361998[/snapback] while i think it looks cool and all, i just wonder how hard setting up the correct geometry is? not to mention the stock arms are made from Mild steel, ive seen quite a few sets of destroyed upper a arms from yfzs. (yes i know the frames are mild steel as well) but the arms are not made out of the same thickness steel. Quote Link to comment Share on other sites More sharing options...
sanddragon2004 Posted April 30, 2005 Report Share Posted April 30, 2005 while i think it looks cool and all, i just wonder how hard setting up the correct geometry is? not to mention the stock arms are made from Mild steel, ive seen quite a few sets of destroyed upper a arms from yfzs. (yes i know the frames are mild steel as well) but the arms are not made out of the same thickness steel. 362328[/snapback] That bike looks like the banshee yamaha SHOULD BE BUILDING! Quote Link to comment Share on other sites More sharing options...
sanddragon2004 Posted April 30, 2005 Report Share Posted April 30, 2005 That bike looks like the banshee yamaha SHOULD BE BUILDING! 362374[/snapback] IMAGINE HOW MANY FREGIN BANSHEES THEYD SELL IF THEY WHERE SETUP LIKE THAT FROM THE FACTORY! Quote Link to comment Share on other sites More sharing options...
Donoyfz450 Posted April 30, 2005 Report Share Posted April 30, 2005 while i think it looks cool and all, i just wonder how hard setting up the correct geometry is? not to mention the stock arms are made from Mild steel, ive seen quite a few sets of destroyed upper a arms from yfzs. (yes i know the frames are mild steel as well) but the arms are not made out of the same thickness steel. 362328[/snapback] I actually havent seen very many YFZ UPPER A-arms bent,,,but have seen ALOT of lower A-arms bend. the uppers are alluminum and yes,,,the lowers are mild steel. Infact, that is why my YFZ has Housers on it now,,,,A friend of mine swore he could handle my quad about five minutes before he hit a tree with it. Luckily no one got hurt but he did pay for my Housers!! Quote Link to comment Share on other sites More sharing options...
