BANJO Posted April 28, 2005 Author Report Share Posted April 28, 2005 ok.. my shee is running a bit ritch.. iv checked everything... so i should switch to 290.. and 27.5?? with 1.5 turn or the screw.. i havent had my carbs apart.. is this somthing i should do my self.. ?? anyways.. i just want all my power.. peace devin.. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted April 28, 2005 Report Share Posted April 28, 2005 (edited) What jets are in there now? How do you know it's running rich...did you check old plugs, or...did you buy brand new ones, warm it up, put the new plugs in and take a wide open run? Old plugs don't help...especially if it's been ridden a few times, idled, etc. Jetting is pretty easy... Check the sticky at the top of the forum for a great, print out for reference article. A little rich is ok....very rich is not. Better to be a tad rich than lean... I can't say those will be your exact jets...I'm just saying start on the rich side, and work your way down. I've never used FMFs. They like a rich Pilot...from what I've only read here. I'm sure a 27.5 would be fine to start...you MIGHT have to bump to a 30....maybe. I'd start at 310. See how it goes from there. If it bogs at WOT, it's rich. POPS...lean. Edited April 28, 2005 by dajogejr Quote Link to comment Share on other sites More sharing options...
BANJO Posted April 28, 2005 Author Report Share Posted April 28, 2005 well.. it dosnt show any signs of anything.. thats what i mean its so hard to figure out what jetting i need.. but yeah like i say to.. better a bit rich then lean.. ill go with them sizes and see how she goes thanks.. peace devin Quote Link to comment Share on other sites More sharing options...
dajogejr Posted April 29, 2005 Report Share Posted April 29, 2005 Ride for a few minutes. If it's still white...it's lean. Richen it up a bit... Quote Link to comment Share on other sites More sharing options...
sredish Posted April 29, 2005 Report Share Posted April 29, 2005 well.. it dosnt show any signs of anything..thats what i mean its so hard to figure out what jetting i need.. but yeah like i say to.. better a bit rich then lean.. ill go with them sizes and see how she goes thanks.. peace devin 361879[/snapback] do a search for plug chop, then go do one. you want to run a wot run with the throttle pegged in at least 5th gear for 3 or more seconds, 6th would be good to, then pull the clutch and kill it. coast to a stop and then pull the plugs and look at the color. a search will give you all the info you need. when you find out the color, get back to us and we'll tell you how it is. Quote Link to comment Share on other sites More sharing options...
Banshee~ Posted April 29, 2005 Report Share Posted April 29, 2005 Just finished up going the jetting routine myself. For sea level to 1000ft. I assume you have a K&N Filter using the stock airbox. What I've read around here is the SST's like a fat pilot. Get a 27.5 Pilot, and turn your air screws 1.5 turns out from seated. 361629[/snapback] I have sst's with a K&N and the lid off, 1000ft. above and im runing 320 mains 30 pilots. 32.5 pilots where to fat. Quote Link to comment Share on other sites More sharing options...
