bigscary Posted April 26, 2005 Report Share Posted April 26, 2005 (edited) I was at the dunes saturday going from 3rd to fourth........I think I probably over reved a bit......mainly because I couldn't get it out of third gear......here are some pics.....please help me figure out what is wrong....... the right piston is fucked and so is the dome......but the left side looks great........ crank and rods feel tight and rods appear to be straight.... what the hell happened here...? Edited April 26, 2005 by bigscary Quote Link to comment Share on other sites More sharing options...
bigscary Posted April 26, 2005 Author Report Share Posted April 26, 2005 pic 2 Quote Link to comment Share on other sites More sharing options...
bigscary Posted April 26, 2005 Author Report Share Posted April 26, 2005 pic 3 Quote Link to comment Share on other sites More sharing options...
bigscary Posted April 26, 2005 Author Report Share Posted April 26, 2005 pic 4 Quote Link to comment Share on other sites More sharing options...
bigscary Posted April 26, 2005 Author Report Share Posted April 26, 2005 pic 5 Quote Link to comment Share on other sites More sharing options...
H250RHATER Posted April 26, 2005 Report Share Posted April 26, 2005 looks like one side wall was scrapind the skirt of the piston is there any metal shavings in the crank? Quote Link to comment Share on other sites More sharing options...
pimp559 Posted April 26, 2005 Report Share Posted April 26, 2005 YOu probably have a problem with one of your carbs. Quote Link to comment Share on other sites More sharing options...
FULL_METAL_JACKT_II Posted April 26, 2005 Report Share Posted April 26, 2005 DETONATION!!! at least what i think............... could B 2 things Use race fuel!!! 110 oct. or ur 2 lean and it blew up when u starved it 4 gas! (like if u were hall'n ASS in 6th gear 4 a ling time, and coasted till a stop whith the engine on.) I could B WRONG QueeQueg Quote Link to comment Share on other sites More sharing options...
lonestar Posted April 26, 2005 Report Share Posted April 26, 2005 I was at the dunes saturday going from 3rd to fourth........I think I probably over reved a bit......mainly because I couldn't get it out of third gear......here are some pics.....please help me figure out what is wrong....... the right piston is fucked and so is the dome......but the left side looks great........ crank and rods feel tight and rods appear to be straight.... what the hell happened here...? 360123[/snapback] It looks like your c- clip to your rispin was'nt seated in all the way. I know, it happen to me. Looks like the same thing. Quote Link to comment Share on other sites More sharing options...
1800bigk Posted April 26, 2005 Report Share Posted April 26, 2005 hi,what was your carb / jetting setup and how much timing advance did you have? Did you ever check your cylinder temps after several hard runs, if so what were they? Quote Link to comment Share on other sites More sharing options...
bigscary Posted April 26, 2005 Author Report Share Posted April 26, 2005 (edited) hi,what was your carb / jetting setup and how much timing advance did you have? Edited April 26, 2005 by bigscary Quote Link to comment Share on other sites More sharing options...
Wallrat Posted April 26, 2005 Report Share Posted April 26, 2005 Looks like you snagged an exhaust port. Check the edges of the exhaust port, is it chamfered? Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted April 26, 2005 Report Share Posted April 26, 2005 damn it looks like that piston melted. i would check the cylinders to see if something was catching. otherwise it looks like maybe your right side carb was plugged and caused that bitch to run way lean. Quote Link to comment Share on other sites More sharing options...
wayfst Posted April 26, 2005 Report Share Posted April 26, 2005 looks like your piston fell in to your exhaust port. burn downs due to timing or lack of fuel show on the intake side of the piston. this looks like it caught and broke the edge, then the pieces just bounced around on top. there may have been some that went down the side, i would pull your crank and check. sorry dude Quote Link to comment Share on other sites More sharing options...
Capone Posted April 26, 2005 Report Share Posted April 26, 2005 Looks like you snagged an exhaust port. Check the edges of the exhaust port, is it chamfered? 360174[/snapback] Indeed.. I would check exhaust port for snags. What pistons did you run? Also, if you know for sure the jetting was on... I would say there was an airleak on the right side intake tract due to the bright white on the piston itself-> x-lean. Usually severe detonation causes a hole in the top of the piston, but to be safe what octane in the sunoco? 220lbs is a hell of a lot of compression, You need @ least 110. I would also drop the timing down to +4, I mean come on, you already got cheetah's.. quit trying to be greedy... Quote Link to comment Share on other sites More sharing options...
