220 Mains Big Enough?
quad4me
Let me start off by saying that you need to learn to read the plugs. Your plugs will tell you whether you need to go up or not, better than we can, all we can do is give you "guesstimations".
Now, I think a 240 might be better suited than a 220. I'm not real familiar with jetting 2-1 pipes tho and 220 sounds awfully lean to me for any aftmkt pipe. I was thinking maybe 260 or 270.
Do a search for plug chop and do it pronto, that will tell you exactly what you need to do.
Scott
I'm pretty sure the 2-1 pipes jet leaner than typical twin pipes, however, a search for dynoport in the jetting area only should yield results that could get you the info you need.
Scott
359394[/snapback]
Thats correct, im surprised a texan could figure that one out :lol: . 2 into 1 Pipe & silencer:4-5 sizes larger on the mains, 0-1 sizes larger on the pilots, adjust airscrews- got that off Banshee Jetting FAQ
359402[/snapback]
The plugs dont seem to bad....I cannot get an accurate Chop...as I have only small neighborhood to ride. People like to call cops on 4wheelers around here. So as far as a chop.....might have to find me a spot.
In general....the bike was set up by a shop in NC, but I thought it seemed a bit lean. I will do some calling to DynoPort myself...see what they say.
>>and may I add.....Rejetting is a BITCH with TORS.
any secrets?
any secrets?
359448[/snapback]
Take it off. Its useless anyway, could be troublesome in the future, and as you pointed out. It will be much easier to jet
