First race
nevermind boys. i was riding yesterday and it started to leak gas like madd out of the carb and then also my axle felt really screwed up. so this week ima order some ale bearings and ill prolly race next weekend :D  thats what im hoping for anywyas. and hey can anyone tell me what to do to replace my axle bearings? thanks later
359083[/snapback]
First you were a little scared,and now this??? I think I smell something......Just screwing with you bro (had to do it).Let us know how you do when you get out there next weekend.
Pull the axle out and remove the carrier, or leave it on if you want to. If you dont care about the existing bearings, hit em out with a hammer and a socket..doesn';t matter what size... When you put the new ones in, MAKE SURE THE SPACER IS IN THE MIDDLE, or else you'll just end up ruining those bearings and more...Make sure to grease every part (Spacer, Bearings, Seals) Then get a socket, i dont know what size it is, but its pretty big obviously, just make sure its on the outside lip on the bearing, not the middle ring...then hammer those bad boys in.. Or if you have a press thats even better.. Oh, and make sure you put the Seals in the right way :P ...And while your at it, get a clymer manual... it tells you how to do everything..
Eric :cheers:
