YFZ Shocks and LSR Race +2+1 a-arms
The ride is much improved over stock, and the range of adjustability is great. Havent taken it off any big jumps yet, but I'm going to hit the track on sunday.
After installing did you run in to any problems with the the tires turning too far?
358816[/snapback]
Yes, my left rim would hit the back of the lower a-arm. But i think it was just because of too much negative camber. Easy fix.
358816[/snapback]
I went riding on Sunday, I actually did run into this problem. Going around a berm, turning right, my right tire opened up so much, I almost flipped my bike. Does anyone know what would cause this, I'm going to mess with the camber, and caster some more, and maybe double-check the wheel alignment.?
