stockridinshee Posted April 21, 2005 Report Share Posted April 21, 2005 I cant really tell because i dont know all that much but when im stoped and i rev it to the moon and let the clutch go it wont do a wheelie and it dosnt spin the back tires either but it is revving. i dont get it though because when the cement is wet i can smoke em all day? and in gravel i dont want it to and it spinds em.it seems if you open the throttle all the way it doesnt pick up fast it just revs but if you eas into it about maybe half throttle its much much faster. is this my jetting? i have a k&n with no lid or snorkle and all i did was go up on the mains jets one (im at 210) should i go up more or do i need to be looking into a clutch? thanks in advance, Dan Quote Link to comment Share on other sites More sharing options...
dajogejr Posted April 21, 2005 Report Share Posted April 21, 2005 Seeing as how we're nearly neighbors...down good ol 94...you're at the same elevation as I am. What other mods do you have? Pipes, reeds, etc? Just removed air box snorkel and lid with a K&N filter? I'd say you might want to go 220 or 230 on the mains, if NO other mods. 200 is stock, you're letting in more air now. Did you adjust your air screws at all? Since you're flowing more air, might want to turn them in a 1/2 turn. 2 out from the seated position is stock....in is a bit richer... How do your plugs look? Ok...best way to tell a clutch....that I've found. Start out in second gear. get rolling to a nice easy coast. With the clutch lever let out all the way...pin the gas. If it starts revving and going nowhere...it's clutch time. If it kinda bogs..picks up...and starts revving clean and pulling...I'd say clutch is fine. Changed the oil lately? Quote Link to comment Share on other sites More sharing options...
stockridinshee Posted April 22, 2005 Author Report Share Posted April 22, 2005 i dont have any other mods as of now but ill try the jets and i know for sure i can start in second gear with stock gearing. my plugs also look good and i change myt oil every 4 or so rides. thanks for the help man Quote Link to comment Share on other sites More sharing options...
yanks5164 Posted April 22, 2005 Report Share Posted April 22, 2005 same thing happened on my bike but i think i just need and adjustmend b/c theres no free play in my lever Quote Link to comment Share on other sites More sharing options...
dajogejr Posted April 22, 2005 Report Share Posted April 22, 2005 A good rule of thumb is you should have about an 1/8 inch or so of free play where the lever meets the perch...or, around 1/4 inch free play at the END of the clutch lever. Remember, when the clutch heats up, the plates expand...and they need that slack... I used to ride my CR a bunch back in the day down there by you...well, actually Belleville. It was a gravel pit, mostly. Last time I was there was about 4 years ago...though...they're turning it into Condos...go figure. Quote Link to comment Share on other sites More sharing options...
sheefreak Posted April 22, 2005 Report Share Posted April 22, 2005 If its reving and you are not going anywhere I would say you better check your clutch fibers. I think your jetting is a little lean also, but it won't rev and not go anywhere even if it is lean. Quote Link to comment Share on other sites More sharing options...
stockridinshee Posted April 22, 2005 Author Report Share Posted April 22, 2005 (edited) ok just rejetted up to 230's and changed my oil .It runs good but i still have the reving problem but now it seems worse. also when i pull the clutch lever in all the way it sticks and i have mess with it to get it unstuck i sprayed the cable and the thing on top of the case( i know im a noob) with alot of wd40 to see if that was it and its not. please help i really dont wanna have do the clutch thing ... thanks again Edited April 22, 2005 by stockridinshee Quote Link to comment Share on other sites More sharing options...
dajogejr Posted April 22, 2005 Report Share Posted April 22, 2005 A new clutch cable is about 20 bucks.... However...once you replace that, if it still doesn't work, it's maintenance time. You may or may not need new plates. But, since you're gonna need to remove the side cover anyways for adjustments or maintenance...replace it anyways with a new one. Quote Link to comment Share on other sites More sharing options...
FIRST BANSHEE Posted April 23, 2005 Report Share Posted April 23, 2005 when your replacing your clutch I would also check the basket, the fingers my be wore and need replaced. Quote Link to comment Share on other sites More sharing options...
