lovin the elkas
1sreamin350
Janssens +3 +1 Elka shocks w/res
The only thing I've noticed, that I dont like, is the bump steer. I just have to adjust the shocks to a softer setting, doesnt cure the problem but helps out alot.
Im still glad I bought them but wish I had a adjustable axle now :rolleyes:
Edited by 1sreamin350
DD, the softer setting may make the frontend ride lower and more along the travel range of stock arms.  just a thought, lemme know what you think.
358303[/snapback]
Perhaps I was reading too much into it, I thought he was talking about compression settings? The only way to "soften srping settings" is to change rates. Changing ride height by the pre-load adjuster will change the tie-rod angle slightly, but he has Jansens, not stock arms.
  • 2 years later...
1screamin350 can you tell more about your LT Janssen setup. How bad is the bumpsteer? Does it feel stable at high speed? How are slow, tight turns? How does it handle whoops, big jumps and landings, etc. I am thinking i am going to go with LSR a arms either in +2+1 or +3+1, but i have also considered the Janssen LT setup. i wish someone around here owned a shee with these set ups so i could try them out, or at least see them in person!
