Stator problem?
i recently washed the shee and for the first time ever it would run right.it would idle perfect but any throttle and it acted like it had a rev-limiter, broke up bad.no head lights either.after a day of drying rand perfect but stil nolights.i ride at night alot and need these.anyone had this problem?my stator has volts coming to the yellow and black wire coming out of it.any suggestions?can i check the stator some other way?thanks.
Check to see if the bulbs are both blown. If so you may have a bad voltage regultor or the wire came off of it. It's the silver box near the cdi in the back.
358045[/snapback]
i'll try the regulator.its not the bulb though because my tail is out also and that is a 5 led set up.would the bike run ok w/a bad regulator?
Yep.
You may just have a bad stator, but you said you are getting voltage out righ. Maybe you have a ground that came off.
358068[/snapback]
yes is am getting voltage form the stator that increases w/rpm.i will take the flywheel off tommorrrow and see what i have.is this where it is grounded?thanks for the feedback
358103[/snapback]
if you are getting voltage from the stator then the regulator has to be bad.
358105[/snapback]
Well im trouble shooting.i have a parts banshee that runs.i tried the voltage regulator off of it to no avail.i also took off the dyna ignition and tried the stock computer.no luck still.thanks for the advice all.any other suggestions?
GET A METER AND MESURE THE RESISTANCE BETWEEN THE YELLOW AND BLACK WIRE!!
CLICK HERE 2 TROUBLE SHOOT!!!!
QUESTION 31
Edited by FULL_METAL_JACKT_II
