Anyone have a g-force axle review
bkrummel
I was wondering if there is any slop in the ends when you start playing with different widths. I seen a lonestar that was kind of sloppy.
360962[/snapback]
Really?
I think there would be a difference in brands for anyone who like jumping. Land on the rear left or back wheel only with a +4 axel you are at a much higher risk of bending something.
360962[/snapback]
Rod,
There is no play in the axle hubs. The width is adjusted with spacers and then the hub is bolted on tight with the axle nut. I've seen durablue elimator axles (the kind with the pin on hubs) that had a bunch of slop in them but the g-force has a good fit with the factory hub splines. No slop on mine.
  • 9 months later...
i have a gforce in my wifes banshee and its pretty much identical to my durablue eliminator .. exept the axle nut .. ya the fit and finish nice and its strong too!!! she slid into a tree and bent the swing arm but the axle is fine!!! :clap:
Edited by Wicked98Shee
how long on average does it take to do the swap from stock to theis gforce one? Do I need any special tools?
I got mine installed in about 5-10 minutes. You'll probably want to go ahead and drop the few extra dollars on the wrench that they sell for the axle nut, unless you just happen to have a 70mm wrench laying around.
