sno_pro27 Posted April 19, 2005 Report Share Posted April 19, 2005 what kindve advance should i do with my mods? who sells timing keys too? will i have to do any re jetting? Quote Link to comment Share on other sites More sharing options...
BdBanshee Posted April 19, 2005 Report Share Posted April 19, 2005 I would just go +4 or +5 degrees, shouldn't have to rejet, just check it to be sure. Quote Link to comment Share on other sites More sharing options...
05bansh Posted April 19, 2005 Report Share Posted April 19, 2005 Screw the timing key, get the adjustable plate from ricky stator. Quote Link to comment Share on other sites More sharing options...
sheefreak Posted April 19, 2005 Report Share Posted April 19, 2005 Screw the timing key, get the adjustable plate from ricky stator. 357318[/snapback] Second that! I wouldn't go anymore than +4 or unless you're running racing fuel. Quote Link to comment Share on other sites More sharing options...
sredish Posted April 19, 2005 Report Share Posted April 19, 2005 what kindve advance should i do with my mods? who sells timing keys too?will i have to do any re jetting? 357149[/snapback] so nobody's really going to help this guy out? Just mod your stock timing plate. You'll want to extend the holes to the left, allowing you to rotated the plate clockwise. 1mm of rotation = 1 degree of advance, so you'll want to rotate it 5 or 6 degrees. You can search for modding timing plate or something similar and find pics and all kinds of info, plus IT"S FREE and safer than a key. Quote Link to comment Share on other sites More sharing options...
fixitrod Posted April 19, 2005 Report Share Posted April 19, 2005 I measured my ricky stator plate and it was 4.5mm for 4 degrees. That's a good base for the banshee. YOu can cut the screw slots on the stator plate 4.5 mm and get the advance for free. Ricky Stator plates are only $35 and you can see how much advance you have. Quote Link to comment Share on other sites More sharing options...
sredish Posted April 19, 2005 Report Share Posted April 19, 2005 Ricky Stator plates are only $35 and you can see how much advance you have. 357346[/snapback] Which is still too cheap to be buying keys.... oh and thanks for the info rod. Quote Link to comment Share on other sites More sharing options...
sno_pro27 Posted April 21, 2005 Author Report Share Posted April 21, 2005 Which is still too cheap to be buying keys.... oh and thanks for the info rod. 357351[/snapback] Thanks guys, one more thing where do i get the ricky stator plates at? On an old post some guy was running +8, with octane boost, couldnt i run somewhere close to that with turbo blue, its usualy between 105-110 Quote Link to comment Share on other sites More sharing options...
05bansh Posted April 21, 2005 Report Share Posted April 21, 2005 http://www.rickystator.com/pages/Yamaha_Ba...ming_plate.html I dont know if I would go +8, that pretty far to me. I think I would stick around +4 - +6 Quote Link to comment Share on other sites More sharing options...
