AnthonyG213 Posted May 26, 2005 Report Posted May 26, 2005 I just ordered the F.A.S.T clutch kit and perch lever. Cant wait till it arrives. I think im gonig to go with the 6 heavy duty springs even though i just got bolt ons. If u were to do a 3/3 on springs were would you get 3 stock springs. Any poniters from those who already have installed the clutch Quote
dajogejr Posted May 26, 2005 Author Report Posted May 26, 2005 I put three of my old springs back in...no issues at all. Just rotate the pattern, should you do it. 1 HD, 1 Stock, and so on around the wheel. Just be careful putting it back together. Easy to snap those bolts... tighten 'em in a criscross pattern like you'd tighten lugnuts on your vehicle. 7.4 Ft./ lbs of tourque is all that's needed. Quote
OR_Banshee Posted May 26, 2005 Report Posted May 26, 2005 If all your mods consist of are bolt ons I would probably go with 3/3. I use all 6 HD with a regular clutch lever and don't think its bad at all. Personally i'd rather have a stiffer clutch and know i'm getting all the power to the ground. Your going to dig the hell out of this clutch kit. Did you order the inner/outer hubs and basket? If Jeff didn't mention it to you, you may want to think about getting the shift spring mod while your clutch cover is off. HUGE difference in going through the gears... Quote
FASTOYS Posted May 26, 2005 Report Posted May 26, 2005 AnthonyG213, if you need some stock springs call me or pm me and i will give you some free if needed. Quote
dajogejr Posted May 26, 2005 Author Report Posted May 26, 2005 If all your mods consist of are bolt ons I would probably go with 3/3. I use all 6 HD with a regular clutch lever and don't think its bad at all. Personally i'd rather have a stiffer clutch and know i'm getting all the power to the ground. Your going to dig the hell out of this clutch kit. Did you order the inner/outer hubs and basket? If Jeff didn't mention it to you, you may want to think about getting the shift spring mod while your clutch cover is off. HUGE difference in going through the gears... 374144[/snapback] I agree. I origingally had all 6HD in there. My arm was Popeye's...and I have a brand new cable and EZ perch. Went to 3/3 with my bolt on mods, and much easier. I'm going with's Jeff's porting, hopefully soon....and then right after his basket setup... By then, I"m sure it's going to need the basket/hubs AND 6HD springs. I can't wait to see the look on my buddies who ride their 450Rs...the one has NEVER ridden a ported shee.... Jeff...I seemed to have lost 2 of the left over 3 HD springs (which I took out). I'm gonna get a new set of 6HD once I have you set up my cylinders anyways... Thanks again for all you do...Jeff... Quote
jeepman380 Posted May 27, 2005 Report Posted May 27, 2005 I just got one of these clutch kits but i'm waiting for my Rockets to get here. Once I get it runnin' i'll put up a review. Quote
FASTOYS Posted May 27, 2005 Report Posted May 27, 2005 I agree. I origingally had all 6HD in there. My arm was Popeye's...and I have a brand new cable and EZ perch.Went to 3/3 with my bolt on mods, and much easier. I'm going with's Jeff's porting, hopefully soon....and then right after his basket setup... By then, I"m sure it's going to need the basket/hubs AND 6HD springs. I can't wait to see the look on my buddies who ride their 450Rs...the one has NEVER ridden a ported shee.... Jeff...I seemed to have lost 2 of the left over 3 HD springs (which I took out). I'm gonna get a new set of 6HD once I have you set up my cylinders anyways... Thanks again for all you do...Jeff... 374154[/snapback] No problem man , thats what we're here for !! Quote
Klotzban1 Posted May 30, 2005 Report Posted May 30, 2005 What all does Jeff do in the ..."Fun Port"? Just wondering? Quote
locogato11283 Posted May 31, 2005 Report Posted May 31, 2005 What all does Jeff do in the ..."Fun Port"? Just wondering? 375516[/snapback] just give him a call and talk to him about it. im sure its enough to make you have an accident in your shorts... Quote
Klotzban1 Posted May 31, 2005 Report Posted May 31, 2005 I've already have a wiseco .020 K140 kit with Pro lites coming. Can he still make me something out of all that..its a light bore job. Quote
FASTOYS Posted May 31, 2005 Report Posted May 31, 2005 I've already have a wiseco .020 K140 kit with Pro lites coming. Can he still make me something out of all that..its a light bore job. 375673[/snapback] Different people require different styles of porting to meet their needs. Feel free to give me a call 785-364-5325 sometime and discuss options ! Quote
Klotzban1 Posted June 1, 2005 Report Posted June 1, 2005 Sounds like a plan to me. I have your number and hope to talk soon. Thanks for replying. Go F.a.s.t.!! Quote
FASTOYS Posted June 1, 2005 Report Posted June 1, 2005 Sounds like a plan to me. I have your number and hope to talk soon. Thanks for replying. Go F.a.s.t.!! 376007[/snapback] Quote
97banshee350 Posted June 1, 2005 Report Posted June 1, 2005 does F.A.S.T racing have a sight that i could just order right from there or should i just call? Quote
locogato11283 Posted June 1, 2005 Report Posted June 1, 2005 does F.A.S.T racing have a sight that i could just order right from there or should i just call? 376063[/snapback] give JEFF @ FAST a call at 1-785-364-5325... Quote
