Best Clutch to use
cudaz101
OK...I think I need a new clutch soon...It is slipping a bit even after I changed the oil few times now. The adjustment marks are way off "The Arrows on the Lever poistion & The Case" but I am not sure if just re-adjusting it will fix the issue. I just would rather not go to the trouble of trying the adjustment only to find out I need anew clutch????
AND I am not sure what is the best route to go since all I want to change is the disks...I would rather not go through Yamaha on this one. I can get the EBC clutch kit through Tucker Rocky, but I am not sure if it is a good way to go with a stock basket???
Brad
If you do a search you'll will find multiple opinions on the best.
Adjusting the clutch will not make it not slip. It will make it release all the way when you pull the clutch handle.
354495[/snapback]
Thanks...Should have done a search....Loads of info out there on this...Thanks ROD...
Brad
get the street bike clutch. call Jeff @ FAST racing 1 785 364 5325. he can set you up with it. its about 95 bucks plus shipping. well worth the money. we been runnin it in our 4mm strokers for a while now with no slipping, not even on a dyno. tell him Tyler Clark gave you the number...
It's stock fzr 600 fibers (stock banshee fibers) and barnett springs and steels according to someone else the called and ordered it.
354546[/snapback]
thats right. also on ther back of the package it came in there was a list of like 50 different models that clutch fixed. alot of them were just different years but theres a few other bikes that it fits as well.
