Won't pull 6th
Guest LRDshee
Guest LRDshee
I run 15-41 gearing and my mods are in my sign. When i shift to 6 it's falling off the pipe and i have to clutch if i want keep it screaming. No probs with the other gears. :confused: Jetting seems to be a little on the rich side. Do you think that rejet will fix that? Or milling head, advance timing?
354209[/snapback]
Rejet and clean your air filter(s). That should do the trick. Check your oil and plugs while youre at it.
354209[/snapback]
Correct jetting will help, and so will advanced timing and increased compression.
