Guest LRDshee Posted April 12, 2005 Report Share Posted April 12, 2005 I run 15-41 gearing and my mods are in my sign. When i shift to 6 it's falling off the pipe and i have to clutch if i want keep it screaming. No probs with the other gears. Jetting seems to be a little on the rich side. Do you think that rejet will fix that? Or milling head, advance timing? Quote Link to comment Share on other sites More sharing options...
chapmanmd Posted April 12, 2005 Report Share Posted April 12, 2005 I run 15-41 gearing and my mods are in my sign. When i shift to 6 it's falling off the pipe and i have to clutch if i want keep it screaming. No probs with the other gears. Jetting seems to be a little on the rich side. Do you think that rejet will fix that? Or milling head, advance timing? 354209[/snapback] Rejet and clean your air filter(s). That should do the trick. Check your oil and plugs while youre at it. Quote Link to comment Share on other sites More sharing options...
BdBanshee Posted April 12, 2005 Report Share Posted April 12, 2005 I run 15-41 gearing and my mods are in my sign. When i shift to 6 it's falling off the pipe and i have to clutch if i want keep it screaming. No probs with the other gears. Jetting seems to be a little on the rich side. Do you think that rejet will fix that? Or milling head, advance timing? 354209[/snapback] Correct jetting will help, and so will advanced timing and increased compression. Quote Link to comment Share on other sites More sharing options...
J-Madd Posted April 12, 2005 Report Share Posted April 12, 2005 What's your compression? Quote Link to comment Share on other sites More sharing options...
Guest LRDshee Posted April 12, 2005 Report Share Posted April 12, 2005 What's your compression? 354222[/snapback] I put a 01 motor (never rebuild) in the shee last summer, at 115 psi Quote Link to comment Share on other sites More sharing options...
FIRST BANSHEE Posted April 12, 2005 Report Share Posted April 12, 2005 timing and compression will help. trinity 2-1 setup is awesome also. Quote Link to comment Share on other sites More sharing options...
fixitrod Posted April 13, 2005 Report Share Posted April 13, 2005 Most likely to rich. Have had the same problem. What's your mods and jetting right now. Quote Link to comment Share on other sites More sharing options...
Guest LRDshee Posted April 13, 2005 Report Share Posted April 13, 2005 Mods are in my sign, don't really now wath is the jetting now but when i checked my plugs, they were dark dark brown (mostly black) Quote Link to comment Share on other sites More sharing options...
