justinklumb29 Posted April 7, 2005 Report Share Posted April 7, 2005 Iam tearing my motor down and was wondering if there is any way to remove the clutch basket without the special tool THanks Justin Quote Link to comment Share on other sites More sharing options...
DIRTBIKEZ Posted April 8, 2005 Report Share Posted April 8, 2005 You can rivit a steel and friction plate together then jam a rag between the basket and the tranny input gears. Quote Link to comment Share on other sites More sharing options...
BdBanshee Posted April 8, 2005 Report Share Posted April 8, 2005 Just use the correct socket and an air or electric impact, the nut spins right off. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted April 8, 2005 Report Share Posted April 8, 2005 Just use the correct socket and an air or electric impact, the nut spins right off. 351555[/snapback] im in agreement here. Quote Link to comment Share on other sites More sharing options...
ledofthezep Posted April 8, 2005 Report Share Posted April 8, 2005 im in agreement here. 351575[/snapback] Yepper! Quote Link to comment Share on other sites More sharing options...
broke Posted April 8, 2005 Report Share Posted April 8, 2005 Yepper! 351576[/snapback] Another yes. Quote Link to comment Share on other sites More sharing options...
RNBRAD Posted April 8, 2005 Report Share Posted April 8, 2005 Another yes. 351636[/snapback] Nope you all are all wrong!!! J/K I probably should of tried that. I did what DIRTBIKEZ did cept I bolted the friction and metal plate together. Quote Link to comment Share on other sites More sharing options...
fixitrod Posted April 8, 2005 Report Share Posted April 8, 2005 Both work. Depends if you have an impact or not. You can also weld some tabs on a piece of steel (a long handle) that slide into the grooves of the inner hub to hold it in place. Quote Link to comment Share on other sites More sharing options...
PUSH THE THROTTLE Posted April 8, 2005 Report Share Posted April 8, 2005 Or you could use a clutch holder too. Quote Link to comment Share on other sites More sharing options...
sheefreak Posted April 8, 2005 Report Share Posted April 8, 2005 Just use the correct socket and an air or electric impact, the nut spins right off. 351555[/snapback] Works everytime, just tough when it comes time to torque it back down, might want to go w/fixit's idea for this reason. Quote Link to comment Share on other sites More sharing options...
fixitrod Posted April 8, 2005 Report Share Posted April 8, 2005 Works everytime, just tough when it comes time to torque it back down, might want to go w/fixit's idea for this reason. 351950[/snapback] The fiber and steels put together with a wrag in the gears works for this too. I think I had to use two steel when I use to do it that way though. The started to twist and want to come out. I suppose it would work with one steel and one fiber screwed together if you can keep it straight in there. Quote Link to comment Share on other sites More sharing options...
BdBanshee Posted April 9, 2005 Report Share Posted April 9, 2005 Works everytime, just tough when it comes time to torque it back down, might want to go w/fixit's idea for this reason. 351950[/snapback] I just impact it back on, never a problem yet. Quote Link to comment Share on other sites More sharing options...
