Dopeman0012 Posted April 7, 2005 Report Share Posted April 7, 2005 (edited) When i was changing my oil i noticed metal flakes or chips draining out with the oil. I checked my service manual for the symptom and it said "something is drastically wrong internally and the engine will have to be disassembled for inspection and repair". Now up to this point everything is fine. Its running fine and cant detect any strange noises. So: Is it a serious problem? And What might be the problem? thx Edited April 7, 2005 by Dopeman0012 Quote Link to comment Share on other sites More sharing options...
fixitrod Posted April 7, 2005 Report Share Posted April 7, 2005 Are they steel or aluminum...(use a magnet to tell). They could be from wear and tear of the clutch basket and parts or gear pieces depending how bad it is. Quote Link to comment Share on other sites More sharing options...
MILO Posted April 7, 2005 Report Share Posted April 7, 2005 yikes, that's not good. may be minor, may be major. only one way to tell, start searching. Quote Link to comment Share on other sites More sharing options...
Dopeman0012 Posted April 8, 2005 Author Report Share Posted April 8, 2005 Well its not aluminum any other ideas? I'll eventually take a look but i first wanted to see if it was a big deal and if so what it could be. I really just wanted someone to say that it was normal. Quote Link to comment Share on other sites More sharing options...
MotulMonsta Posted April 8, 2005 Report Share Posted April 8, 2005 If it's not aluminum, then it's your gears. When you shift hard and slam it in gear, you can chip them. Perhaps that's where the metal's comin from. Quote Link to comment Share on other sites More sharing options...
01bansheefox Posted April 8, 2005 Report Share Posted April 8, 2005 If it's not aluminum, then it's your gears. When you shift hard and slam it in gear, you can chip them. Perhaps that's where the metal's comin from. 351720[/snapback] I didnt think the crank was alum? Couldnt it be little shavings off that? I saw on my right side if woren down alot more than left Quote Link to comment Share on other sites More sharing options...
