+4 stroker mod ?
Thinking of building up the shee for more power. Last one had mild porting with t5 pipes,shaved head and +4 timing. Looking for more. How much increase will I see with a stroker +4 set-up and pipes (fatties or t5 not sure yet) ?Is the spacer plate the best or a modded head? Do mostly trail riding but some road dragging. Looking to kick some ass bad.
Most of the pwr is in the porting I believe. 4mm stroker isn't a huge stroke increase but does yeild some extra pwr. If your motor is due for a crank and your going to port, that's the way to go.
You would be suprised at the pwr a good builder can pull out of a stock crank motor with good porting/pipe combo/carb combo. You may just want to look at that route and save the $400-$500 for the crank.
Edited by PassionRE
