SDD Posted April 8, 2005 Author Report Share Posted April 8, 2005 if the tors is for not letting the slides go up when the throttle is stuck then how come it still works when you have it pinnned 6th? 351393[/snapback] BFS the TORS does not physically control the carb slides. Infact the TORS system is really only active when the thumb throttle is close (idle position). How would we know this? The TORS boxes on top of the carbs are wired in series so if one switch inside either of the boxes doesn't close when the throttle is at idle the TORS kills the ignition. Quote Link to comment Share on other sites More sharing options...
SDD Posted April 8, 2005 Author Report Share Posted April 8, 2005 Whats all the confusion about? The most "important" function of the system is if the little switch in the thumb throttle tells the black box you're off the gas but the switches on top of the carbs says you're on it, it'll rev down. 351447[/snapback] Thanks Dirtbikez for trying to lighten things up... I kind of wanted to reply back on Shee K's last reply to whom ever deleted it but it's cool because it would have turned into one ugly roost thread. It's nice to know you moderators are out there trying to keep the forum clean (Thanks). Quote Link to comment Share on other sites More sharing options...
racer Posted April 8, 2005 Report Share Posted April 8, 2005 I thought the TORS was just for the ebrake? So you couldn't gas it when the brake was on? Dunno. ;x 351268[/snapback] no, thats the smokey burnout elimination device. Quote Link to comment Share on other sites More sharing options...
fixitrod Posted April 8, 2005 Report Share Posted April 8, 2005 They wouldn't put a device that "let go" of the slide because it's to complicated. Thanks SDD, that was the simple version and just an extension of BenBB's. Quote Link to comment Share on other sites More sharing options...
01bansheefox Posted April 8, 2005 Report Share Posted April 8, 2005 take it easy, and take it as a free bump Its the thought that counts like people say, atleast he posted. Quote Link to comment Share on other sites More sharing options...
