ELMER Posted April 5, 2005 Report Share Posted April 5, 2005 HEY GUYS WHERE IS THE BEST PLACE TO ORDER CARBS FROM? Quote Link to comment Share on other sites More sharing options...
Bansheeracer Posted April 5, 2005 Report Share Posted April 5, 2005 I have a set thats 3 weeks old! im going to alky i paid 340.00 for the carbs (pair). Ill sell you the carbs, K&N filters, and cable for the same as the carbs by them selves! Pm me if interested! Quote Link to comment Share on other sites More sharing options...
SDD Posted April 5, 2005 Report Share Posted April 5, 2005 I have a set thats 3 weeks old! im going to alky i paid 340.00 for the carbs (pair).Ill sell you the carbs, K&N filters, and cable for the same as the carbs by them selves! Pm me if interested! 350090[/snapback] If you didn't get the filters and cable for that price you got ripped off. Check out www.carbparts.com or www.sudco.com Quote Link to comment Share on other sites More sharing options...
1800bigk Posted April 5, 2005 Report Share Posted April 5, 2005 I know that Alba is usually really high priced, but they have 34pj's at a good price. $259 http://alba.buyol.com/Item/016%2D039.htm Quote Link to comment Share on other sites More sharing options...
RBD Posted April 5, 2005 Report Share Posted April 5, 2005 I personally do not like the PJ carbs and think a PWK is a much better choice. If you still want a PJ carb check out the TRX guys as most all of them have removed their PJ carbs and replaced them with PWK's. Quote Link to comment Share on other sites More sharing options...
Koolguyson Posted April 5, 2005 Report Share Posted April 5, 2005 I agree with SDD, you got ripped off in a bad way. Quote Link to comment Share on other sites More sharing options...
fixitrod Posted April 5, 2005 Report Share Posted April 5, 2005 Here's a good place too. pro-flo.. Here's a link http://www.pro-flo.com/proflo_keihin_flat_slide_carbs.htm#Keihin PJ Series That page has the pj's pwk's pwk air stryker on it. Quote Link to comment Share on other sites More sharing options...
fixitrod Posted April 5, 2005 Report Share Posted April 5, 2005 (edited) Here's the newer pwm series. I like it!!!! pilots and mains through the float bowl!! Hmmmm Anyone tried them??? edit Nevermind, they only come in 38mm Edited April 5, 2005 by fixitrod Quote Link to comment Share on other sites More sharing options...
BURKE_DADDY Posted April 6, 2005 Report Share Posted April 6, 2005 how do the pj and pwk differ from one another? thank you Quote Link to comment Share on other sites More sharing options...
fixitrod Posted April 6, 2005 Report Share Posted April 6, 2005 Once again I'm going past a quote for www.ericgorr.com because he knows his shizit Kehin has several different models. The most popular ones are the PJ, PWK, and PWM. The PJ is used on Honda CR125, 250, and 500 models from 1985-1997 The slide is oval shaped and there are no additional pumps, its just a simple carb. In fact it's so simple that the choke and idle screw share the same jet. The PWK was the next step up from the PJ. The PWK has a crescent shaped slide and a separate idle circuit from the choke. The PWK is used on Kawasaki KX125, 250, and 500 models from 1990-97. The latest version of the PWK features a pump to supply extra fuel in the mid-range. The PWM is similar to the older PWK (no pump) and the overall length is shorter. Hope this helps Quote Link to comment Share on other sites More sharing options...
