help please! 99 shee
c00t3r
ok first off i want to know what i did wrong with the mods i did, first off i have the stock carbs that have been bored 2mm oversized with k@n clamp ones, i have pc pipes, jetting is 35 pilot and needle in 3rd clip and 340 mains plugs look good, also i have a +2 timmig degree key and the motor has prolites .5mm over no porting! gearing is 15 41
ok my buddy has toomey t5,s and he has v force and i know that it is bored 40 over kn clamp ons. now what i dont know is if he is ported becasue he bought it this way. from what i have said do you guys know why he is beating me on the road? i have a custom nos system but i only use it in the sand i thought that i would be able to take him on motor. but i guess not. from what i said up top is there anything wrong with my set up? and if you could help me out i would greatly appreciate it and also if i want to port my motor who would be the best to do the work? and if the piipes are junk i would like to know that too when i got the bike it had the pc on so i left them what about rockets? would the t5,s make that much difrence against the pc pipes? thanks in advance!
andy
F.T.R
location michigan :yank:
#311
andy
F.T.R
#311
349350[/snapback]
your pilot is way to big try 27.5 your timing can be advanced +2/3 more degrees.your gearing sounds a tad tall for a very mild setup like yours,sounds like your buddy most likely has a good port job and running vforce really help out the power too. pc arent bad pipes theyre just not suited for play drag racing or aggresive portwork,t5s would make better power IMO and it kinda sounds like rockets would be your best bet and a dune port job from passion/patriot/a.s/southern ,theres many options here, do a search and ask people about the porting in there signature.good luck :cheers:
349450[/snapback]
30 pilot jet and your pipes are fine.I do porting and have won many drags and flat track races with pro circuit. They rev just as far as toomeys ,just not as good chrome.Porting is every thing when it comes to going faster. go back to stock sprocket unless you run 18s on the rear.
I think its a combo of his lower gearing, Toomys, and v-force all giving a slight advantage. You could possibly be a size or 2 rich on the main wich could drop a couple ponnies and you could go to +4 or 5 on timing. PC pipes are all right, I think the Toomys would be better in a drag through, probably a slight top end advantage. Porting would help you the most. There are many builders to choose from, do some reading on the HQ to learn about the many names out there.
  • 3 weeks later...
Sounds rich all the way around to me. If you are running nos in the sand maybe you should check your compression. May be time for a rebuild also. Nos can be mean on a motor.
350284[/snapback]
Pro circuits are a good pipe.My friend's bike runs good.His has a 400 main jet.May be too much where you ride.Going from a pc to a T-5,won't help you a whole lot.Porting really wakes a banshee up.Good investment.
call me crazy .. but a 35 pilot is like :whoa: ... im ported with pods v force pc pipes and i run a 30 pilot on 410 mains... sound a lil rich on the pilot.. im suprised it starts... get some port and you wont need to change those carbs..
im also thinkin along the same lines as gearing too though..
Edited by NEVER SATISFIED
well, the pilot is probably too big, but it isn't going to make or break the top end. Is it starting ok? I'd also say run a compression check and a WOT plug check if you haven't already. If he's ported at all, then he's gonna be making good power as long as he's got it jetted right.
