Damn lights!
Hargh!
Was riding last night and for about 10 min lights kept dimming on me, then finally went DEAD.
engine or performance was not lost
could this b Voltage Regulator????
M
Hargh!
M
349051[/snapback]
yes. See if the blue wire came uplugged from the voltage regulator (the silver box beside the cdi). It happened to me once.
Are the bulbs blown? If they are, the voltage regulator is bad, and too much voltage was sent to the lights. (same as if it came uplugged, in my case). If not, it is most likely something else.
350478[/snapback]
Good point about the bulbs !!!!
If they are fine the lighting coil side of the stator is gone.... as long as there is no loose wire.
The stator has two sets of coils. One for lighting and one for ignition. Here's a pic.
Standard stator from www.rickystator.com
High output (Being for lighting)
A quick note here; I checked the stator's ohm readings according to the Clymers and it was real close to the proper readings (like a couple ohms). I said hell with it and bought a new one, and sure enuff that was it.
:cry: Damn sure is that Stator!! :cry:
Checked the Ohms and NOTHING!!!!
Could of FK'd-it up when i was advancing my timing. SHIT!!
do U think Ricky Stator will Fix it 4 me?? it is a Ricky Stator
M
Edited by FULL_METAL_JACKT_II
350844[/snapback]
I had one that was reading fine and it was bad :confused:
At least you found the problem!!
