justinklumb29 Posted April 3, 2005 Report Share Posted April 3, 2005 I am just about ready to send my cylinders out, but cant deciede between the two, eric is cheaper but is his work cheaper?. Iam going to be looking for a trail port (low to mid range) Its more than likely going to be run with fattys and maybe a two into one carb. Quote Link to comment Share on other sites More sharing options...
bkabina Posted April 3, 2005 Report Share Posted April 3, 2005 Give Jim a call and talk to him on the phone. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted April 3, 2005 Report Share Posted April 3, 2005 i had a passion setup and my brother had a gorr woods port. his bike could keep up with me pretty easily. his bottom end and midrange was unreal and it still pulled hard on top. if i were you i would call eric. cheap porting but his work is by no means cheap. there are several members on this site that have gorr portwork and im pretty sure they have no complaints. Quote Link to comment Share on other sites More sharing options...
white trash Posted April 3, 2005 Report Share Posted April 3, 2005 I cant say anything for Gorr, since i have no expierience with him. But i just got my passion motor runnin, and it rips Quote Link to comment Share on other sites More sharing options...
1800bigk Posted April 3, 2005 Report Share Posted April 3, 2005 You need to ask yourself a few questions before you decide. 1. how much do I want to spend? 2. how fast do I want to go? 3. how good are my tuning skills. gorr port job = $225 makes 58hp passion regular port = $375 prolly makes similar hp passion 12 port = $500 may make a little more but needs big carbs and big exhaust to get your moneys worth out of it. this port job can be tempermental to tune. Quote Link to comment Share on other sites More sharing options...
H250RHATER Posted April 3, 2005 Report Share Posted April 3, 2005 You need to ask yourself a few questions before you decide. 1. how much do I want to spend? 2. how fast do I want to go? 3. how good are my tuning skills. gorr port job = $225 makes 58hp passion regular port = $375 prolly makes similar hp passion 12 port = $500 may make a little more but needs big carbs and big exhaust to get your moneys worth out of it. this port job can be tempermental to tune. 349013[/snapback] i got jims mx port(regular port) and im pushin 72hp Quote Link to comment Share on other sites More sharing options...
erbilabuc Posted April 3, 2005 Report Share Posted April 3, 2005 (edited) so you are making 72hp with stock stroke and his cheap port job? Thats awesome considering that his 12 port 4 mil stroker made 77, you are the man! Where did you get it dynoed at? Edited April 3, 2005 by erbilabuc Quote Link to comment Share on other sites More sharing options...
wesw Posted April 3, 2005 Report Share Posted April 3, 2005 You need to ask yourself a few questions before you decide. 1. how much do I want to spend? 2. how fast do I want to go? 3. how good are my tuning skills. gorr port job = $225 makes 58hp passion regular port = $375 prolly makes similar hp passion 12 port = $500 may make a little more but needs big carbs and big exhaust to get your moneys worth out of it. this port job can be tempermental to tune. 349013[/snapback] stephen motor had bigger carbs on it to make 58 hp and t5. so it about the same on parts not the port work. as far as jetting jim motor, i put some cgl needles in 5th clip, it pulls like a bitch, ask jim cause i had him help me tune it. plan to get some dgl adn try them out adn will have it dailed in. my advice is for you to talk to both porter, see what setup they recommend, pipes, carbs, etc. i sure both's work is great, you will have to decide on the money and what setup issue you want. jim builds a great motor, takes a little tuning but ive given you great advice on the jetting. Quote Link to comment Share on other sites More sharing options...
erbilabuc Posted April 3, 2005 Report Share Posted April 3, 2005 as far as jetting jim motor, i put some cgl needles in 5th clip, it pulls like a bitch, ask jim cause i had him help me tune it. plan to get some dgl and try them out and will have it dailed in. 349028[/snapback] damn you are still messing with your jetting, havent you had that passion stuff for months now? just goes to show that passion stuff is very hard to tune. Quote Link to comment Share on other sites More sharing options...
chris642 Posted April 3, 2005 Report Share Posted April 3, 2005 You need to ask yourself a few questions before you decide. 1. how much do I want to spend? 2. how fast do I want to go? 3. how good are my tuning skills. gorr port job = $225 makes 58hp passion regular port = $375 prolly makes similar hp passion 12 port = $500 may make a little more but needs big carbs and big exhaust to get your moneys worth out of it. this port job can be tempermental to tune. 349013[/snapback] another thing to remember that a bore job is included in that $375 with passion, so that means you need another $100 for pistons, and you are going to want a coolhead. i think on my setup the stock head would have given me like 100 PSI, and i think i have 19cc domes which bring it to 145 PSI. I love it, its a bottom end port job and it is insane on pavement. i gotta get around to changing out the front sprocket because i have it geared way too low right now, all it does is spin in the dirt. Quote Link to comment Share on other sites More sharing options...
justinklumb29 Posted April 3, 2005 Author Report Share Posted April 3, 2005 thanks for all the replies, I think that iam leaning towards eric a little bit, I will give him a call tommorow and talk to him Quote Link to comment Share on other sites More sharing options...
fastbanshee4u Posted April 3, 2005 Report Share Posted April 3, 2005 These are not the only people who do porting. If your not a hard core racer the $225 sounds good though. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted April 3, 2005 Report Share Posted April 3, 2005 thanks for all the replies, I think that iam leaning towards eric a little bit, I will give him a call tommorow and talk to him 349076[/snapback] you wont be disappointed... Quote Link to comment Share on other sites More sharing options...
stclark816 Posted April 3, 2005 Report Share Posted April 3, 2005 i got jims mx port(regular port) and im pushin 72hp 349017[/snapback] Dyno sheet? 72hp, stock stoke, mild woods.mx port is hard to believe. Especially when his 4mm drag port motors are puttin out around 77hp. Im not knockin Jim's work, people say their shit hauls, but that sounds sketchy to me. Quote Link to comment Share on other sites More sharing options...
H250RHATER Posted April 4, 2005 Report Share Posted April 4, 2005 he did more porting than the mx port just not a drag or 12 port he opened the ports up more than the regular mx port Quote Link to comment Share on other sites More sharing options...
