New V-Force 2 Reeds
kb7kuh
Greetings All!
I have a 2004 Shee mods are FMF Gold Series Fattys, Duel K&N's, Boost Bottle, Mains are 310's and Pilots are 37.5's Air screws set at 1 1/2 turns. Tores gone, Motor Stock. Allways run at Sea Level. It's a real chore to start when cold. :angry: After it warms up, it will start with 1 kick and runs Strong (no boging)
I just installed a set of V-Force2 reeds. Do I need to rejet? I fired it up (same as befor hard to start) and it idles fine (once it starts) and winds up and sounds real good. I hope to get it to the dunes on the 9th, and will put in a fresh set of plugs to see what it's doing. Any sugestions?
Thanks,
Don
AKA
BansheeX
I have basicly the same set up as you,( except for the dual K-n-N's..i'm running only one biggie) and riding elevation...
i was running the 27.5 pilot, and Someone on here told me that Fattys like it leaner....so i put the 25 back in, and richened the needle one...she liked that a lot better, specialy now that the weather is getting nicer (warmer)....Just a thought....
it's in here somewhere...not too long ago either... :cheers:
Edited by Otis
Anymore sugestions? I'm going to try to get a test run tomm. between rain showers. It's weird, once it starts it idles fine, and all the way through the powerband it runs and pulls hard. I'm using 16oz to 4 gals. (40 to 1 I think) I will also try the Choke trick to see if that makes a difference.
Edited by kb7kuh
348433[/snapback]
If you are using 16oz to 4 gals you are closer to 32:1. 16oz with 5 gals is 40:1
My fatty's like a leaner pilot... they still do with a 4mm motor and different carbs...lol. Mine liked a on clip leaner on the needle too but that was with stock reeds. You'll have to play with your jetting.
Strange thing is the symptoms you have with the pilot are those of the pilot being to lean. Unless your compression is low !!!
Did you happen to clean the carbs when you put now reeds in? I just had same exact symptoms as you. I had a friend who has a business do some quick carb work for me cause I couldn't do it in time for a trip, turns out he put float bowls back on wrong carbs. They have to be on correct carb or choke won't work for right side. If you look inside your float bowls, they are numbered 1-1, and 1-2. 1-1 goes on left side carb w/ckoke slide. I run almost same setup as you and I run 30 pilots, runs great, starts great.
Edited by sheefreak
351863[/snapback]
No I didnt take the carbs apart. I rode it Saturday and it screams. I kind of hate to start change anything cause from idle to WOT it rips. Guess I will try going one position richer on the neddle and see what happens. I can allways go back.
Thanks Everybody!!!!! You guys ROCK!!!! :cheers:
